Tamiya Direct Drive Touring Car >
Like Tree92Likes
Old 11-22-2010, 08:57 PM
  #1531
kneedeeppow's Avatar
Originally Posted by 92gsr View Post
I was curious too so I asked my friend google and found this:
Parts Needed To Convert A F103 To A F103GT
51242- B Parts
51229- T Parts ( may need 2, I can't remember how they were packaged)
51227- R Parts
51232- Rear wheel Mount L
51231- Rear wheel Mount R
51233- Diff Joint
51088- Urethane Bumper
4005112- Chassis Plate
4025043- Upper Deck( if you dont have one already)
9400389- Shaft Bag (has the front axles and the longer king pins for the front suspension)
If you want to run the Courage body you also need the Courage bumper parts #9000030.
I have no idea who wrote this so I can't give credit.
thanks for that,good searching
kneedeeppow is offline
Old 11-24-2010, 11:24 PM
  #1532
got some more questions folks. with the rear wheel mounts and diff housing,do i need both of these or just one or the other?
http://cgi.ebay.com/3RACING-2mm-Offs...item3cb1f70613
http://cgi.ebay.com/3RACING-ALU-Diff...item588aa1f541
and does the axle from a rm go into a gt or is the gt axle longer?
cheers
Old 03-08-2011, 10:51 PM
  #1533
lightfoot's Avatar
Default UF1 Series
2011 UF1 season will start this Saturday at West Australian Coast Grand Prix...
8 races , 8 tracks, 1 race per month, 1 2011 UF1 Champion...
For details, check out:
http://www.charleslightfoot.com/UF1/UF1_home.html
lightfoot is offline
Old 08-07-2011, 05:12 AM
  #1534
heretic's Avatar
anyone has a cheap f103 gt chassis for sale ? no wheels, no electronics, no shell, even if it's damaged... it's for parts. PM me ! thanks
heretic is offline
Old 08-07-2011, 05:17 AM
  #1535
heretic's Avatar
double post
heretic is offline
Old 08-07-2011, 01:14 PM
  #1536
Where in europe are you ?
weekendracer_uk is offline
Old 08-07-2011, 08:26 PM
  #1537
heretic's Avatar
pm sent !
heretic is offline
Old 09-23-2011, 07:12 PM
  #1538
mailboxck's Avatar
Has anyone here tried converting their F103GT into a mini? There's a conversion kit from Field One in Japan:
Link: http://www.rc-field1.com/contents(CHASSIS).html
It's 5,800 yen for the chassis, upper deck, rear shaft, spur gear holder and front king pins. But, just to challenge myself, I'm trying to build one right now from scratch. Looks like you don't need all those parts to build one.
mailboxck is offline
Old 09-23-2011, 08:51 PM
  #1539
That is a nice conversion. My F103GT is just sitting on the shelf collecting dust. Sounds like a good winter project.
X
X-Factor is offline
Old 09-24-2011, 02:06 AM
  #1540
mailboxck's Avatar
I'm quite excited to get mine built. Had to mold my own FRP and shave it to the dimensions i need it to be. When i finally complete it, it should be around 225mm wheelbase, or the M setting in the mini.
I'm just curious though how it will handle.
Old 10-02-2011, 04:26 AM
  #1541
mailboxck's Avatar
Project F103GT mini:
Old 10-03-2011, 07:47 PM
  #1542
Mailboxck......Very Nice. Looks like the rear axle might need to be cut down on the driver side, lines up pretty good on passenger side. What body do you plan to run on it?
X
X-Factor is offline
Old 10-03-2011, 08:01 PM
  #1543
MD
MD's Avatar
Trader Rating: 131 (100%+)
There's a kit for that conversion.
MD is offline
Old 10-03-2011, 08:08 PM
  #1544
MD
MD's Avatar
Here's the conversion kit.
MD is offline
Old 10-05-2011, 01:27 AM
  #1545
mailboxck's Avatar
Yep Field 1 does make a kit but the one they make is the short wheelbase. The one I made is med wheelbase (225mm). I also wanted to prove that you don't need all the parts in the Field 1 kit to make one.
I'm still waiting for a part I ordered from Tamiya to make the rear width correct. I need to replace the right side joint to an F104 diff joint found in the F104 PRO kit. Then, I have to cut down the shaft on both sides to make the width correct.
I'm looking at either an Fiat 500 Assetto Corse body or an MX-5.
