LRP Q2 Question
Old 11-21-2005, 06:36 PM
farls3589's Avatar
Default LRP Q2 Question
I have an LRP Q2 and when I try to use a digital servo, my personal transponder does not work. Does anyone have a solution to this problem or an explination on why it is doing so?
farls3589 is offline
Old 11-21-2005, 07:23 PM
Still Bill's Avatar
Trader Rating: 15 (100%+)
Digital servo is pulling too much power and the QC2 cannot handle the load.
You need to be specific about what servo and receiver you are using to get the right answer.
Still Bill is offline
Old 11-21-2005, 08:35 PM
farls3589's Avatar
I am using a KO reciver and a KO servo.
Old 11-21-2005, 08:43 PM
Still Bill's Avatar
My experience with the QC2, KO digital servo and Spektrum receiver was that I could not them to work together. Added recommended capasitors with no luck. May be the same for your equipment combination.
Good luck!
Old 11-21-2005, 09:41 PM
farls3589's Avatar
OK. thanks anyway
Old 11-21-2005, 10:55 PM
Have a KO digital receiver (KR-297FZ) and a KO servo (2143), never had any problems with the transponder.
pops is offline
Old 11-22-2005, 12:20 AM
asw7576's Avatar
1. Could be bad connection ( transponder's plug is loose or it doesn't bite the pins inside receiver ).
2. The personal transponder is damage.
asw7576 is offline
Old 11-22-2005, 05:28 AM
Tommy Bergfeldt's Avatar
I'm running Spektrum with digital KO Servo and the PT still makes good hits, the same with the standard 302-reciever. Must be a bad connectionor something with your PT
Tommy Bergfeldt is offline
Old 11-22-2005, 08:33 AM
Nipple's Avatar
Well,
I think it may depends on what class are you racing in.
If you run modified class, when you are exiting a corner with full power, the sudden surge will cause the DP transponder to be off.
Quite a common problem in my country. So some drivers will use a small 170mah or less batt pack to power the receiver.
Nipple is offline
Old 11-24-2005, 12:17 PM
farls3589's Avatar
thanks for all the help but im sure i will figure it out i was using somone elses servo so that could be the problem.
Old 11-24-2005, 03:34 PM
pheyhoe's Avatar
Hook your PT wires up to the battery leads going to the speedo never missed a single lap on my system. Using KO 2343 and 301F, QC2.
pheyhoe is offline
Old 11-24-2005, 05:46 PM
BlackKat's Avatar
I know that the LRP Quantum's put out 4.8v on the BEC rather than the standard 6v
Hope that helps you solve the issue somehow
-Dan
BlackKat is offline
Old 11-24-2005, 07:38 PM
Safer SX's Avatar
I have a problem with a LRP Quantum when I hook the Ko Pro PDS 2344 the servo jitters and yes I have tried servo after servo they are all brand new but if i put my gt7 speedy in the servo works fine can anyone help
Safer SX is offline
Old 11-24-2005, 09:03 PM
Super Moderator
Trader Rating: 22 (100%+)
Bingo its the BEC circuit. Switch out to another Speeder or put an analog servo in there. Thats why my servo in my touring car is a 93157. I have a JR8450 waiting but I know I will have problems if I try to run that.
Bob Barry is offline
Old 11-24-2005, 09:19 PM
farls3589's Avatar
I decided to go with an anolog and that worked with the Q2 and it is not that much worse.
