TC3 Diff Housings. >
TC3 Diff Housings.
TC3 Diff Housings.
Old 11-21-2005, 03:09 PM
vectra's Avatar
Default TC3 Diff Housings.
I am thinknig of fitting alloy diff housings to my tc3.
What I need to know is, will the housings from the Nitro TC3 fit ?
cheers
vectra is offline
Old 11-21-2005, 03:26 PM
anthony390's Avatar
yes but you will need shorter CVDs
ntc3=200mm cars(wide body)
tc3=190mm car
anthony390 is offline
Old 11-21-2005, 03:30 PM
vectra's Avatar
Why would I need shorter cvd's ?
I am only talking about using these .?
vectra is offline
Old 11-21-2005, 03:34 PM
anthony390's Avatar
oh i tought u were talking about the outdrive
anyways yes it will fitt perfect
just remember not to srew alluminum with alluminum screws
so you if your gonna use blue alluminum screws, you can only use the top part of the diff case
Old 11-21-2005, 04:12 PM
PaZ
PaZ's Avatar
y's that then?
PaZ is offline
Old 11-21-2005, 04:22 PM
anthony390's Avatar
the case will strip or the screw will stip, maybe even both! (alluminum screw with alluminum case)
Old 11-21-2005, 08:21 PM
I use aluminum screws in aluminum parts all the time. The trick is not to overtighten them and don't use 10 gallons of threadlock. If you do regular maintanence on your cars you shouldn't have any problems using aluminum screws in aluminum parts. You can't just screw everything together and then forget about them.
killswitch is offline
Old 11-21-2005, 08:53 PM
anthony390's Avatar
ya i do TOO, its just that is what every body else says
Old 11-22-2005, 03:25 AM
PaZ
PaZ's Avatar
ive alwayz been tempted by the ally cases cause they will go well with the rest of my blue its the only part i dont have and sumone told me they run smoother?
PaZ is offline
Old 11-22-2005, 04:00 AM
vectra's Avatar
Bought them
$31.99 for full sett, Front and Rear.
vectra is offline
Old 11-22-2005, 06:24 AM
PaZ
PaZ's Avatar
nice let us know how they go i might get some soon
PaZ is offline
Old 11-22-2005, 07:01 AM
I got a set of those housings a while ago. I didn't like them. The bearing slots were sloppy. I had to cut on one side of the housing and build up CA to fix the side that was to large. They are also heavy compared to the stockers. The only thing I liked was they looked pimp on my BMI chassis.
Old 11-22-2005, 07:08 AM
Mr. Shookie's Avatar
THEY ARE HEAVY WHICH DOES NOT ADD ANYTHING BUT MORE DRAG AND MORE WORK FOR YOUR MOTOR TO PUSH ALONG THE TRACK........
When I had my TC3.....seems like ages ago now...
I did the hole blue up everything...all it did was slow my lap times down...
If you are more interested in the Bling Bling factor...Kool those are right up your ally but if you race...You are better off with the grafite ones and some Titanium screws...Those aluminum ones just like to strip too much for my liking..
-Shookie <><
Mr. Shookie is offline
Old 11-22-2005, 07:46 AM
wyd
Tech Legend
wyd's Avatar
Trader Rating: 51 (100%+)
I was thinking of them just for the bottom half in the front and then use the graphite setup in rear and graphite top case with the alum bottom in front. Mainly because no more stripped screws. Not sure what a stock FT TC4 weighs in at nowadays since I have not weighed the car.
wyd is offline
Old 11-22-2005, 12:29 PM
vectra's Avatar
[QUOTE=killswitch]I got a set of those housings a while ago. I didn't like them. The bearing slots were sloppy. I had to cut on one side of the housing and build up CA to fix the side that was to large. QUOTE]
Were they the exact same as those ones ?
If so, Are you saying I would be better off not getting them ?
vectra is offline
