TC3 steering upgrade >
Old 11-21-2005, 07:29 AM
Default TC3 steering upgrade
Is there an upgrade for these cars. I have replaced the rack and all the ball cups and still have a lot of slop in the steering.
rockdog200 is offline
Old 11-21-2005, 07:32 AM
burbs's Avatar
the slop should actually help keep the car more stable.If there isnt a ton.. If it is all new it should be fine... i noticed when i took out all the slop the car was very twitchy.. put it back in and it worked better..
burbs is offline
Old 11-21-2005, 07:43 AM
anthony390's Avatar
same thing to say as ^
anthony390 is offline
anthony390's Avatar
(BURBS)
LOL
Old 11-23-2005, 11:07 AM
I had a TC3 w/ BMI chasis.
I converted the TC3 steering rack to the NTC3 steering swing arm setup. "The holes where already in the BMI so I didn't have to drill any."
I still had slop in the steering.
M2Racing is offline
Old 11-23-2005, 11:24 AM
timmay70's Avatar
anything with ballcups has slop. the more cups the more slop. I agree with the assesment that it helps stabilize the car if there is not too much slop. If it is excessive it can be mistaken for a servo not centering up.
timmay70 is offline
Old 11-23-2005, 11:56 AM
Default sloppy seconds.
I also had a bmi w/the TC3 rack. It handled much better. I also had a hi-teck servo, metal gear hith torque. (forgot the number) But it had a TON of slop just in the servo itself. So I replaced it with a futabe 9451. Since...much better. Waht I would do...is take a look at your car... hold the servo arm...check slop...then...check the slop of just the servo itself and see where you are getting the majority of slop. If your car has been running for a long time, it might be time to change your ball cups..as they do wear and produce more slop then they should.
acyrier is offline
