Old 11-23-2005, 09:10 AM   #31
anthony390's Avatar
Send a message via AIM to anthony390
ya i know, i hate the way some brands say it was made just for something
but then you can find the exact same thing AND ITS CHEAPER
anthony390 is offline   Reply With Quote
Old 11-23-2005, 11:58 AM   #32
Big Jim always recommended the Lysol for cleaning motors,I haven't bought a can of motor cleaner in years.
Hyper1 is offline   Reply With Quote
Old 11-23-2005, 12:47 PM   #33
anthony390's Avatar
so lysol really does work?
if lysol works shouldnt windex also work?
Old 11-26-2005, 09:49 AM   #34
Make sure it is Basin Tub and Tile Cleaner. The stuff that foams up. Regular Lysol will prob work a little due to the alcohol in it, but not what i was talking about.
Dodgersfan is offline   Reply With Quote
Old 11-26-2005, 10:25 AM   #35
TadehI's Avatar
Use non-chlorinated brake cleaner its safe with graphite and carbon and won't damage any electrical components, you could also use lighter fluid.
TadehI is offline   Reply With Quote
Old 11-27-2005, 08:59 PM   #36
anthony390's Avatar
YUP... Lysol works
Old 11-30-2005, 09:41 PM   #37
anthony390's Avatar
what happens if it is not non-chlorinated
just curous of what might happen
Old 11-30-2005, 11:55 PM   #38
Send a message via Yahoo to crazymechmow
the regular brake cleaner has ill effects on plastic and will usually ruin it just ask my 300.00 snapon battery charger that was sitting by the trash can in the shop. some over spray mist got on the lens that covers the gauge while I was spraying of a couple brake drums and fogged it over. it etched the plastic lens so you can't read it and snapon wants 50.00 for a new gauge so get the non chlorinated or use lysol.
crazymechmow is offline   Reply With Quote
Old 12-01-2005, 12:01 AM   #39
anthony390's Avatar
F*^k that must suck
anyways thanks ill make sure not to use it
Old 12-06-2005, 10:08 PM   #40
anthony390's Avatar
any tips while i am rebuilding my motors
Old 02-05-2006, 03:46 AM   #41
rayman's Avatar
Was searching for this thread. I have a compressor and airbrush. Can I use alcohol to clean motors? I heard mixing water and denatured alcohol is ok. Wont rust be a problem? Lysol is just as expensive as motor spray here.
rayman is offline   Reply With Quote
Old 02-05-2006, 12:01 PM   #42
Jochim_18's Avatar
Break/Rotor cleaner is a good alternative when cleaning your motor and they are less expensive and works well. The only down side is they have a strong odor.
Old 02-05-2006, 12:29 PM   #43
BeetleBailey's Avatar
Go to your local O'Reilly's and get some 3M High power brake cleaner. It is part # 08880. I've been using this for a couple of months, and I love it. I can purchase a 12 can case for under $35!
BeetleBailey is offline   Reply With Quote
Old 02-05-2006, 05:50 PM   #44
rayman's Avatar
3M products are way expensive here. Break cleaners here have acetone and really stinks.
Motor Cleaner Evilstealth Electric On-Road 23 11-16-2007 09:53 AM
Motor Cleaner /Brake cleaner PRO 2 RACER Australian Racing 9 10-10-2006 04:44 AM
Ka Boom as a motor cleaner Ducati-Rider Electric On-Road 0 03-20-2006 03:53 PM
Brake dust cleaner or Nitro Cleaner? TurboLancer Electric Off-Road 10 12-04-2004 05:47 AM
Motor Cleaner Substitue jedi Electric On-Road 14 04-23-2003 05:44 AM
