Like Tree63Likes
Destiny RX-10S
Old 04-02-2018, 09:51 AM
  #241
Trader Rating: 64 (100%+)
Thanks that was quick!
PROMODVETTE is offline
Old 04-16-2018, 07:04 AM
  #242
Trader Rating: 57 (100%+)
Ran the new SR this week first time. Need an aluminum chassis on CRC black, but car was great even with carbon. I used a modified version of Carey's Can Nats setup and the car was great first time it hit the track. Really impressed with how it turns and how much grip it generates. Now for some options.
Antimullet is offline
Old 04-16-2018, 07:12 AM
  #243
Xpress's Avatar
Talking
<br />
<br />
Can you really make a handling assessment when running 80t crawler-motor sedan?
Xpress is offline
Old 04-16-2018, 07:39 AM
  #244
I put some comm drops on it and cut brushes. ran like a 17.5.
Old 04-24-2018, 05:59 AM
  #245
Anyone know where to get a tapeless battery hold down system for this?
Previously I modified one from RSD (Christian) to work on another tc I had but I don’t think he sells them anymore.
Old 04-24-2018, 08:03 AM
  #246
Trader Rating: 78 (100%+)
Previously I modified one from RSD (Christian) to work on another tc I had but I donít think he sells them anymore.
None that I am aware of, but you could probably use RSD's battery holder and find some standoffs the correct size. I will keep looking.
RSD XRAY T4 Keyed Battery Holder System
Antimullet likes this.
RBLove is offline
Old 04-24-2018, 08:34 AM
  #247
I purchased a roll of the Slion strapping tape from Xenon. It's supposed to be a little stretchy and not cause tweak - I'll test it this Friday. At first I was skeptical of the tape only/hook less battery mounting on this car but now I like it.
Strapping tape (orange) 50m x 15mm - Xenon Racing Online shop
DavidNERODease is offline
Old 04-24-2018, 03:33 PM
  #248
Thanks fellas. Maybe Iíll just cut some out of this 3mm cf. scrap I have.
Also- why is the destiny at 1.85 ir for stock racing when others are at 2.0ir? I know Yoks change to 2.0 pulleys for stock. Thought you want it shorter than longer for stock and better rip?
Old 04-24-2018, 04:46 PM
  #249
Trader Rating: 9 (91%+)
xray is 1.9
The smaller pulley helps with rotation and corner speed.
Antimullet and phatboislim like this.
Johnny Carey is offline
Old 04-25-2018, 10:46 AM
  #250
Trader Rating: 21 (100%+)
since yall are talking tape, i use 2 small pieces of double sided tape at the extents of the battery and used electrical tape as 'confirmation security'. that setup never let me down
phatboislim is offline
Old 04-25-2018, 11:12 AM
  #251
Trader Rating: 18 (100%+)
Here is my setup sheet from the 2018 MHIC. I qualified and finished 10th in modified. Had hoped for a bit more but luck didn't quite go my way in the mains. The car was quite good, although when traction came up on Sunday I should have made some changes to help settle it down. Unfortunately I just didn't have the time with the schedule and triple mains, so I drove an edgy car for the mains. Let me know if you have any questions.
PDF: http://chrishillier.com/wp/wp-conten..._2018_MHIC.pdf
JPG: http://chrishillier.com/wp/wp-conten..._2018_MHIC.jpg
LloydLoar is offline
Old 04-25-2018, 12:42 PM
  #252
What would you have changed to make it less edgy? Changes to tire preparation, chassis or both?
Old 04-25-2018, 02:04 PM
  #253
I would have tried a bit more front glue. If that was too much in the other direction, I then would have added front camber. Alternately, I thought about trying a different set of tires that I hadn't yet used that day (but had a similar number of runs), but unfortunately my other sets were only glued to ~59.2 or so and I didn't have time to glue again.
DavidNERODease likes this.
Old 04-25-2018, 04:30 PM
  #254
Danger danger runs at 57mm
Old 04-27-2018, 04:08 AM
  #255
The Teacher's Avatar
Trader Rating: 54 (100%+)
Help!!! I'm sure this has been asked before but is there a way currently to get the RX10SR in the states? I looked into Destiny USA but I guess their site is down for updates or maintenance. Looked into Toni Sport but I don't think they ship to Washington DC...what's up with that? Anyway, anybody know where I can get a kit and parts?
The Teacher is offline
