Like Tree68Likes
Destiny RX-10S
Old 02-04-2018, 04:08 PM
  #181
Racermac73's Avatar
Congrats to Yugo for his tq and win at snowbirds in modified tc.. very cool
Gravity Dodger and Dazzk like this.
Racermac73 is offline
Old 02-07-2018, 12:29 PM
  #182
Default Set up sheet for Yugo and Jin @ 2018 Snowbird
Teru is offline
Old 02-09-2018, 07:07 AM
  #183
1shnot's Avatar
Just picked up a rx10s for USGT and I really like the car.. But after few packs later noticed steering rack has pretty good amount of slop, is there a fix or a remedy for this?
TIA
1shnot is offline
Old 02-09-2018, 07:40 AM
  #184
Castradamus's Avatar
Trader Rating: 54 (100%+)
TIA
I would check the bearings first make sure they are still good. This video tell you about adjusting the rack:
Click here
I would also go ahead and do this as well eliminate all issues with the rack:
Destiny RX-10S
Castradamus is offline
Old 02-12-2018, 10:30 AM
  #185
Trader Rating: 21 (100%+)
for the 10s, every other race day you have to take the steering rack off and reset it. it has a tendency to get loose. i heard the new release has a better steering rack
phatboislim is offline
Old 02-12-2018, 10:40 AM
  #186
antlockyer's Avatar
The new rack is the same as the old one as far as my eyes can tell.
antlockyer is online now
Old 02-12-2018, 10:57 AM
  #187
Mach10_shooter's Avatar
Trader Rating: 39 (100%+)
Once the rack is setup correctly and tight it works flawless... I've ran the same car for 6 months and have not even touched the rack...
Gravity Dodger likes this.
Mach10_shooter is offline
Old 02-12-2018, 11:30 AM
  #188
1shnot's Avatar
Have you build it with locktight?
1shnot is offline
Old 02-12-2018, 11:43 AM
  #189
No but I use steel screws throughout as you cannot tighten aluminum enough without stripping or breaking the screw.
Old 02-12-2018, 01:50 PM
  #190
Gravity Dodger's Avatar
I've been using my RX-10S in usgt since the car was built at the 2016 Champs and my steering rack is still slop free and silky smooth. New SR rack uses a slider with a deeper groove than the original and so far has held up good with no washers to prevent it from popping off in a crash.
Gravity Dodger is offline
Old 02-12-2018, 11:57 PM
  #191
antlockyer's Avatar
http://site.petitrc.com/reglages/destiny/SetupSheetsDestinyRX10S.html
Arno has hosted my RC crew chief file for the SR. The CG positions are for a carbon car with ti screws up top and a 50g centre weight.
Enjoy
Old 02-13-2018, 10:38 AM
  #192
when i had it i dont remember using loctite. but i no longer have it, besides i'd be too afraid to use it on that piece
Old 02-13-2018, 10:28 PM
  #193
Trader Rating: 9 (91%+)
I used loctite. Set it and forget it.
Johnny Carey is offline
Old 03-01-2018, 07:51 PM
  #194
Where can you get the SR kit in the states? Thanks
barnacle is offline
Old 03-02-2018, 04:45 PM
  #195
They will be available shortly. Havenít been for sale on the site because of demand. Iíd imagine after roar nats/can nats time frame
