CRC T-Force
Old 11-18-2005, 02:35 PM
gonzo416's Avatar
Trader Rating: 39 (98%+)
Default CRC T-Force
anyone have any good setups or kit info?
gonzo416 is offline
Old 11-18-2005, 06:32 PM
dmatter's Avatar
www.teamcrc.com
dmatter is offline
Old 11-18-2005, 07:44 PM
Ike
Ike's Avatar
I just picked a used one up, seems like a very nice car and the quality is about on par with my Corally. Will be ineteresting to see how the laptimes compare.
Ike is offline
Old 11-19-2005, 05:36 AM
mcmoney's Avatar
20 springs
max caster with 10 degree blocks
silver rear spring with 30 wt oil
Thick t-bar
Tires depend on the class and traction levels
mcmoney is offline
Old 11-19-2005, 05:53 AM
old school front end
20th front spring
gold center spring
30 wt oil
red side spring
crc lower motor pod
this is for carpet racing
ptjonesus is offline
Old 11-19-2005, 07:04 AM
smyka's Avatar
gonzo you runnig stock or mod ?
if you are runnig stock download my set up form clevland last year from the crc web site if runnig mod hook your car up with what mcmoney said
smyka is offline
Old 11-19-2005, 05:24 PM
GMartinez's Avatar
Trader Rating: 87 (100%+)
Im also in the process of setting up for outdoors any suggestions would be helpful.
track conditions very tight & technical surface smooth
GMartinez is offline
Old 11-20-2005, 09:44 AM
whynot's Avatar
Trader Rating: 18 (100%+)
smyka,
I have the t-fource And I am thinking of getting the new pro cut tires,I am running stock.How small can you run the pro cuts.I have my rear axel shimmed for the parma tires now and will I have to change that for the pro cuts.Also do you use the battery hold downs or do you tape your batteries?I am using the 3800 batteries and the hold downs seem to bend a little when I tighten them down.thanks and congrats on all your success in racing.
mike
whynot is offline
Old 11-20-2005, 05:34 PM
smyka's Avatar
i use tape to hold the batteries in .
yes you will have to reshim the rear end i believe the off set is different
as for what you can cut them to maybe johnny wopper will come on here and answer that for you i have not tried any of them so i dont know
smyka is offline
Old 11-20-2005, 05:37 PM
mcmoney's Avatar
The ProCut rims are 38 mm....
mcmoney is offline
Old 11-22-2005, 11:45 AM
gonzo416's Avatar
does the ride height have to be raised as the tires wear? cause i think it would change the handling, probably better but chassis would eventually bottom out
gonzo416 is offline
Old 11-22-2005, 04:36 PM
dakrat's Avatar
tires wear out and ride height is decrease. yes you do need to raise the car as the tires wear out
dakrat is offline
Old 11-23-2005, 12:04 AM
Ike
Ike's Avatar
Well, my fast laps were almost the same between the Corally and the T-fource comparing lastweek and this week. The Corally has been getting faster and faster each week so we'll see if I can do the same with the T-Fource or if I got almost everything out of it setup wise.
On a side note the two cars feel totally different even though my lap times were about the same. The steering links on the Corally, even though they're sloppy, make the car feel so much less jittery down a straight and when making tiny steering corrections. Overall the steering on the CRC felt better, but I think I still have a ways to go on finding a good setup for the Corally. The Corally is a dream to work on compared to the CRC though, I somehow managed to break a T-bar setting my trim before I even ran 1 lap with the T-fource, and was thinking how much easier the swap would have been with the Corally.
Both great cars and it will be fun seeing which one ends up being my car of choice.
Ike is offline
Old 11-24-2005, 07:42 PM
burgboyz's Avatar
Trader Rating: 70 (100%+)
Hey guys, does anyone like to use tweak screws... or side springs....or both....and why?? thanks!!!
burgboyz is offline
Old 11-24-2005, 09:18 PM
Ike
Ike's Avatar
I've only tried the tweak screws in mine thus far. I've only run it once but will try the side springs after a few racedays with the tweak screws.
Ike is offline
