roll out chart on pocket pc >
Old 11-18-2005, 11:15 AM
theisgroup's Avatar
Default roll out chart on pocket pc
any1 have a roll out chart calculator on pocket pc?
theisgroup is offline
Old 11-18-2005, 11:23 AM
ChrisP's Avatar
Here's an awesome rollout calculator by Dr_Hufhurr http://2brainsdesign.com/2BrainsDesi...2003.ARMV4.CAB
If it doesn't have your car's internal ratio, then you can go in and edit the .xml file and modify or add the ratios included and then they will be selectable in the pulldown menu
ChrisP is offline
Old 11-18-2005, 11:26 AM
theisgroup's Avatar
thanks windowsguy99 and dr_hufhurr
Old 11-21-2005, 08:06 PM
SpeedBump57's Avatar
Winds I have spent the last 2 hours tring to do just that and have not had any luck. No matter what I change the default vaule to it will not add it to the list. What could I be doing wrong? I am actually pretty good with computers but for some reason I can't get this figured out. Can you or someone give me a little help here.
Scott
SpeedBump57 is offline
Old 11-21-2005, 09:01 PM
tpczx6's Avatar
Yang just see me at the track I have it in mine pocket pc excel
A1 tire size mm B1 45
A2 pion B2 26
A3 spur B3 96
A4 Ratio B4 =(b3/b2) you would come up with 3.692307692
A5 roll out B5 =B1*3.14/B4 you come up with 38.26875
you can also put in inchs if you want in B1
tpczx6 is offline
Old 11-22-2005, 04:31 AM
ChrisP's Avatar
When I open "appValues.xml" in notepad
it looks like this:
<?xml version="1.0" encoding="utf-8"?>
<appValues xmlns="http://tempuri.org/appValues.xsd">
<internalRatios>
<internalRatio value="1.0" />
<internalRatio value="1.77" />
<internalRatio value="2.125" />
<internalRatio value="2.50" />
</internalRatios>
</appValues>
I have added lines under internalRatios and they hav shown up on my list with no problems at all.
I was unable to edit directly on the pocketpc though, so I simply copied the file to my desktop, edited it..saved it...then copied it back to my ppc and voila! more internal ratio selections!
ChrisP is offline
Old 11-22-2005, 05:27 AM
theisgroup's Avatar
Default thanks tim
i put together one in excel, but wanted something cooler. not that it would make the car any faster. but then again cooler is faster. lol
here is my version if anyone is interested.
File Type: zip
Old 11-22-2005, 06:11 AM
tpczx6's Avatar
boy thats looks like a lot of work but you have it all there in one view
tpczx6 is offline
Old 11-22-2005, 06:22 AM
Well thats the problem then. My download did not come with the file appvaules.xml.
Thanks for getting back to me so quick. Would you mind sending me the version you have in an email if you still have it.
[email protected]
Thanks Winds
Scott
Old 11-22-2005, 06:26 AM
theisgroup's Avatar
that's what happens when you are bored at work.
Old 11-22-2005, 06:40 AM
Theisgroup
Very nice job! What don't you like about that?
Old 11-22-2005, 06:43 AM
theisgroup's Avatar
its in excel
Old 11-22-2005, 06:53 AM
theisgroup's Avatar
for those that have interal gear ratios other then 1
File Type: zip
Old 11-22-2005, 07:03 AM
LOL I used QP since about 1989, I went through all the upgrades and over time everything I made early on was trashed. I made the switch to Excell about 3 years ago and so far I like it better. Of coruse I had to learn VB but it was worth it.
Old 11-22-2005, 07:48 AM
Gael L's Avatar
Is that available for Palm OS?
Gael L is offline
