Old 11-22-2005, 09:11 AM   #16
ChrisP's Avatar
The original was a .CAB file that was exported to the PPC...
Ihad an early version for PPC2002..you will want to talk to dr_huhfurr on here or email him at the adress listed on his site for questions...
IT really is a slick little piece of software
ChrisP is offline   Reply With Quote
Old 11-22-2005, 01:56 PM   #17
SpeedBump57's Avatar
Originally Posted by Killa G
Is that available for Palm OS?
I don't think he has one for the palmOS yet but there are lots of those floating around, here is one of the ones I know of.
http://www.rochesterrc.com/software/...e.php?aid=1914
They were going to make one for PPC but it seems like they never got around to it.
SpeedBump57 is offline   Reply With Quote
Old 11-24-2005, 08:22 AM   #18
Winds mine is a cab file as well, just not the same one you have I guess. I have sent Brain an email but have not herd back as of yet.
Old 11-24-2005, 11:24 AM   #19
koabich's Avatar
Send a message via Yahoo to koabich
Any Excell spreadsheet should work. Just take the formula's and enter them into an excel spreadsheet.
This worked for my Ipaq and it is now working for my Palm OS based Treo 650.
I have a chart on my work computer that I'll post on Monday!
koabich is offline   Reply With Quote
Old 11-25-2005, 11:22 PM   #20
Yep I guess that is what I am going to have to do as I have not herd back from Brain yet. The ones that theisgroup posted are actually pretty cool. Thanks Theisgroup! I guess I am still a software junky at hart.
Old 11-26-2005, 07:45 AM   #21
Mr. McGoo's Avatar
here is a gear chart in excel that i did for my FK05 - you can easily adjust the drive train ratio and pinion/spur size - not a rollout
also here is a 1/12 scale ride height spreadsheet - based on your tire size, there is no more guessing on what axle height adjuster or spacer that is needed for your front...
XRAY | RCAMERICA | HUDY | Team Tamale
Mr. McGoo is offline   Reply With Quote
Old 11-26-2005, 07:52 AM   #22
BritRacer's Avatar
here is my excel ss for FDR and Rollout for 48p and 64p currently has 415, FK05, Mi2, Pro 4
Let me know if you want more cars added....just send me the internal drive ratio
Andy
12th scale 1:1 added
FK05 Added
BritRacer is offline   Reply With Quote
Old 11-26-2005, 07:57 AM   #23
Mr. McGoo's Avatar
jerk face....i was about to post mine, but yours is way cooler....and you already have a bug....the transmission ratio for the FK05 is 1.7, not the 1.9...you can't trust the british for nuthin'....sheesh...
Old 11-26-2005, 08:07 AM   #24
BritRacer's Avatar
lol, Bob N pointed that out too, I thought I had fixed that, Bob did most the color work, I just added the drop down boxes and tarted it up a bit
Old 11-26-2005, 08:11 AM   #25
BritRacer's Avatar
fixed!, well if you must run obscure Slovakian stuff....
Old 11-26-2005, 08:14 AM   #26
Mr. McGoo's Avatar
can you add a 1:1 ratio for the 1/12 scale - that is a way cool chart
Old 11-26-2005, 08:15 AM   #27
BritRacer's Avatar
OK, challenge....can anyone do java? Would love to have this on my cellphone....
compatible with Symbian S40/60???
I would probably pay $10 for such an application...
Old 11-26-2005, 08:18 AM   #28
BritRacer's Avatar
done
Now all I need to do is learn how to use it lol
Old 11-27-2005, 03:10 AM   #29
fastolfart's Avatar
Well heres my modification to whom ever posted the excel roll out calculator earlier.The mods I have put in are total final drive ratio, tyre circumference, rollout, (which will work in metric or imperial) It uses tyre diameter instead of radius, and is small enough to view on a pocket PC screen. (what i am using it for).
There are two to down load, one for 48 pitch and the second for 64 pitch.
(the diff being in the spacing of the spur gear teeth.
To operate, simply input pinion, spur gear, internal ratio and tyre dia.
Once you have put in the basic info, you wont have change much for your current car from there.
have fun with it and let me know how it goes.
PS if you want to run this on a note book or desk top, change all the font to larger size.
It is so hard to fix the driver, but so easy to blame the car.
fastolfart is offline   Reply With Quote
Old 11-27-2005, 06:10 AM   #30
theisgroup's Avatar
yes, but the roll out formula does not take into account imperial or metric and does not care about the pitch of the gears. so why can you not use one? they both end up with the same information.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
FS/FT: Pocket Bike & Razor Pocket Rocket bcane98 Other Items: For Sale/Trade or Wanted to Buy 0 06-09-2007 01:23 PM
I need a roll out chart rcracenut Electric On-Road 4 04-14-2005 09:05 PM
gear ratio and roll out chart rcracenut Electric On-Road 0 04-11-2005 05:30 PM
Gear ratio/roll out chart...how to calculate? jasoncsc Nitro On-Road 5 05-04-2004 12:47 PM
