Changing Direction >
Changing Direction
Changing Direction
Old 11-17-2005, 09:19 AM
Default Changing Direction
Hi every one,
So what changes do you make to make your touring cars change direction faster through twisty sections especially on carpet, Any one think roll bars help?
Xrayskid is offline
Old 11-17-2005, 09:35 AM
sosidge's Avatar
Extra roll stiffness will help, roll bars and/or stiffer springs/dampers will move you in the right direction.
Stiffer may also remove overall grip too, so don't lose the setup balance.
sosidge is offline
Old 11-17-2005, 09:49 AM
What kind of car, type of carpet, tires, mod or stock, etc...
But generally find a good setup on car companies web site as a starting point and then tune to your driving style and track.
Charles is offline
Old 11-17-2005, 09:54 AM
Hi
My first post was aimed at Touring cars in general, so it seems that stiffening the suspension is one of the ways to change direction faster. So harder springs, less droop and a slightly thinner oil. But has any one else got comments on how a roll/sway bar will effect a cars ability to change direction on a twisty carpet track.
Cheers
Xrayskid is offline
Old 11-17-2005, 10:48 AM
Any one like to add anything else?
Xrayskid is offline
Old 11-17-2005, 12:15 PM
comments on how a roll bar effects direction change on a carpet track would be apreciated,
Cheers guys
Xrayskid is offline
Old 11-17-2005, 12:45 PM
Cheers guys
roll bars generally take car reaction away,unless you your shock oil/springs are soo soft.
roll bars are generally used on tracks that are bumpy or very high grip abnd you want some less front grip/body roll
trf racer is offline
Old 11-17-2005, 01:21 PM
Mark G's Avatar
i say look at you cars web site and see if they have any basic setups. but yea roll bars help some wat but its mostly the springs and oil you use to u just got to play around with ur setup to find the right one
Mark G is offline
