Old 10-28-2002, 09:31 PM   #1
fai
Regional Moderator
fai's Avatar
Default About yokomo-typed dampers...
Dear all racers,
I have experience of running diaphragm type dampers but I'm new to yokomo-typed! My problem is that those o-rings always enlarge after about 6 runs and these add a lot of friction to the damper! Why would this happen?? It also happens to diaphragm dampers but I know it would not appear in such short term.
Thanks!
fai is offline   Reply With Quote
Old 10-29-2002, 11:38 AM   #2
007yoshi's Avatar
Maybe they just suck. Youre talkin bout the clear ones, right? MIP supposedly makes the best ones (the blue ones)
007yoshi is offline   Reply With Quote
Old 10-30-2002, 06:27 PM   #3
fai
Regional Moderator
fai's Avatar
Thanks! I think MIP is my way to go!
Old 10-30-2002, 08:33 PM   #4
Jared Kirkwood's Avatar
Send a message via AIM to Jared Kirkwood
fai,
The MIP will swell up as well. Most of us in this area prefer the Associated orings over the MIP. I've never seen the Yokomo shock but my guess the oring has no place to expand to so it places extra pressure on the shock shaft and therefore causes it to bind or create extra friction.
We have this same problem with losi shocks and their cartridges. With the losi shocks you can modify the cartridge to allow for the orings to expand. You maybe able to do the same for the yokomo shocks.
Here is a link to the information some of use put together to modify the Losi cartridge. When doing this we are able to use the orings for a few months besides just a couple of weeks. Maybe you can use the information for a similar fix to your problem.
http://www.coyotehobbies.com/forum/t...?TOPIC_ID=1134
Good luck.
Jared Kirkwood is offline   Reply With Quote
Old 10-30-2002, 11:23 PM   #5
fai
Regional Moderator
fai's Avatar
Jared Kirkwood,
Thanks for your kindly help!!
Old 10-31-2002, 05:29 AM   #6
007yoshi's Avatar
I still find it odd, however, that soo many people have shock orings that swell. I havent touched my shock cartridges in my xxx in years. I'll inspect them , but theyre never swollen . I hope my yok's dont swell
Old 10-31-2002, 09:21 AM   #7
ruf
ruf's Avatar
Send a message via AIM to ruf
MIP will not work on Yokomo, Tamiya or other metric diameter shock shafts. They will leak badly.
Joe Chen
www.reflexracing.net
ruf is offline   Reply With Quote
Old 11-01-2002, 09:01 AM   #8
007yoshi's Avatar
ooooooo didnt think about that
Lay down Dampers Sparky7B Electric On-Road 16 07-14-2009 04:20 AM
Oil Dampers cougardriftr R/C Items: Wanted to Buy 1 11-19-2007 04:58 AM
LF: TRF dampers Edgarski Australia Wanted to Buy 0 06-29-2007 09:45 AM
Dampers surrealmaterial Australia Wanted to Buy 0 10-07-2006 03:48 AM
TRF Dampers Ill Factor R/C Items: For Sale/Trade 9 05-25-2005 10:02 PM
