-   -   TRF Shock question (https://www.rctech.net/forum/electric-road/907538-trf-shock-question.html)
RS_ZACH 01-15-2016 09:50 AM
TRF Shock question
Are you able to use CVA oil shock pistons on TRF damper.... I recently picked up a used Tamiya chassis which has TRF dampers. But the shocks are setup with two hole pistons. I want to use three but currently do not have the TRF three hole pistons to go along with the dampers.
sakadachi 01-15-2016 11:34 AM
If the diameter is the same, then yes. I have the m-chassis version 54000 and use the cheapo CVA super mini damper pistons inside. They work great.
cplus 01-15-2016 03:33 PM
Drill them out?
