Sedan Mod Motor and tire Question >
Old 11-14-2005, 10:57 AM
Default Sedan Mod Motor and tire Question
Hi,
I am preparing to run modified oval sedan. Unfortunately no one knows what a good mod motor would be in terms of Turns and winds. I will be running on carpet at the Birds and could use some opinions on foam tires as well. I looked at Jaco's website and they seemed to be the tire to use in Vegas...can anyone please help recommend what turn and wind motor I should use for oval application? Thanks
Ginsu is offline
Old 11-14-2005, 12:21 PM
I know this is in the on road section, but no one in the oval section seems to know.............any help would be appreciated.
Ginsu is offline
Old 11-14-2005, 01:20 PM
Curtis Schlaht's Avatar
Well, if the rules are anything like the regular oval classes you’ll be running 4 minutes…. SO, go with a 7x1 geared at a 20mm rollout, AND PUNCH IT….
Curtis,
Curtis Schlaht is offline
Old 11-14-2005, 07:12 PM
I have a question on rollout. The rollout I use comes out at .9845 or 1.0 How do you get 20mm?
rockdog200 is offline
Old 11-14-2005, 07:19 PM
Moderator
Speedo's Avatar
Well...
You need to figure out the circumference of your tires. 58mm tires come to about 182mm. (diameter x pi)
You then divide that dumber by the FDR of your car. On my Xray, using a 120t spur and 27t pinion, I get 120/27 x 1.7 (internal drive ratio, specific to car)
Speedo is offline
Old 11-14-2005, 08:18 PM
.9845" = 25.01mm
Curt,
Old 11-15-2005, 06:19 AM
Would the new two stage Jaco's be the tire of choice?
Ginsu is offline
Old 11-15-2005, 06:26 AM
TimPotter's Avatar
Trader Rating: 14 (100%+)
Ginsu,
The sedan oval class at the birds runs a handout 19t( Ultrabird ).
TimPotter is offline
Old 11-15-2005, 06:34 AM
Originally Posted by TimPotter
Ginsu,
WEll, that just took al the fun out of it
Curt,
Old 11-16-2005, 05:22 PM
Thanks Tim,
Any suggestions you can offer for sedan oval?
Ginsu is offline
Old 11-16-2005, 06:25 PM
I suggest not using a regular set up. When you only have to turn left your setup can be "unusual" to be dialed. Like 3 degrees of camber on rf wheel and 0 degrees on the front left. Different foam tires on each corner. etc...
Or get a pan car and use a car made to go in circles
Charles is offline
