Old 10-30-2001, 01:04 AM   #46
spider's Avatar
Send a message via Yahoo to spider
how do you know if a battery cell has gone bad? do you know a voltmeter?
spider is offline   Reply With Quote
Old 11-01-2001, 10:05 PM   #47
xxxlosi's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to xxxlosi
Can anyone help me, I got a yokomo BMS charger but the bad thing is the instruction manual is in japanese, where can i down load a instruction manual in english?
xxxlosi is offline   Reply With Quote
Old 11-03-2001, 06:48 AM   #48
Send a message via ICQ to melvin
Default BX213 or GM Commander
Advise please ..which is better ? Does the KO Propo got lockout feature ?
Will the GMVIS charging work for NIMH ?
melvin is offline   Reply With Quote
Old 11-03-2001, 08:38 AM   #49
Regional Moderator
daniz24's Avatar
BMS and GM Commander are the same each other.
GM has VISCharge dan BMS has YOKOMOCharge.
For NiMH i use 4 A (linear charge) and use 4x1.5 = 6 A with VIS or YOKOMO Charge Mode.
The Power is incredible... More voltage with more runtime?!?!?
daniz24 is offline   Reply With Quote
Battery Charging rf096 Racing Forum 16 06-01-2015 03:24 PM
Charging Ni-Cd battery jayliu1984 Electric Off-Road 8 02-27-2008 11:32 AM
Battery charging Ian C Electric On-Road 3 03-24-2007 10:30 PM
Battery charging help fordman86 Electric Off-Road 12 04-19-2006 11:23 PM
Step Charging Setups micros_rock Electric On-Road 0 06-08-2005 04:53 PM
