BSR Racing M.RAGE mini
#151
Wish I could. I haven't really looked into any kind of upgrades for it. I suggest digging back through this thread. I pretty sure I remember reading about something that worked. I'll dig out the book, see if they give any info on the stock stuff. Let me check another forum, I know another owner.
#152
If you're looking to hit those speeds, I'd get the TOP Racing Sabre 4WD Mini (if you can find one) and call it a day. Yes, it costs a lot more but 10x nicer than the MRage at all levels.
IMHO the MRage is fun for bashing around with maybe a 21T at best in a small course. I still run silver can and I think it's a good balance what the chassis can endure.
#153
Cheers
JJ
#154
Hi, I wondered if you can help. Im interested in the m.rage, but i want to make it propper quick 60mph+ and im worried about the plastic diff gears and plastic diff joint cups.
in the uk it is hard to find the metal diff joint cups. I have been looking and noticed this part from tamiya.
Tamiya 54056 Tb-03 Aluminum Differential Joint Set Tb03 TB Evolution
is it possible these could fit?? i cant find specs on the parts so its hard to know, Im hoping someone with more experience will have an idea of alternative parts I can source in uk, before I invest in the BSR.. I like the bsr mrage because of the small size...
thanks in advance
JJ
thanks in advance
JJ
The Top Sabre 4wd is a unicorn find at the moment - parts drying up very quickly (the metal parts).
MTS T2 mini would be a better bet if you want m-sized car. It uses the Top plastics (which IMO are CRAP)
But to go 60mph in an m-chassis car .... you're much more limited when it comes to body choice so I would really reconsider going for a normal 10th scale.
#155
60mph is possible - I have an MRage with steel gear diffs front and rear and steel transmission outdrives - basically a drivechain that's pretty tough! But it's not a straight forward swap.
I've read all the forum posts n tutorial. I'm clear on process for changing to metal out drives. I'm also clear on the metal diff input gears. One thing I'm not clear on is sourcing metal bevel gear for the diff. Do you know where I can source them in UK, or if there other other 'manufacturer diffs I can use the bevel gears from? Us online stores are too expensive for shipping...
#156
Cheers man,
The gear diffs don't seem to be in stock at the moment though
#157
Sorry for all the questions. The kit is in post to me now so trying to see if I have forgotten anything for the build!!
I have read the kamtec v12 bodies with 205mm wheelbase and 165 track fit fine. Some have been checked for aero so I'm hoping these are a higher speed option. Do u know if these do indeed fit?
#158
I can't remember what spur/pinion came with the car but I remember it seemed to be good for 13.5T boosted so anywhere between 5.5 and 6.5 FDR I think.
There are metal ball diff crown gears being sold by some company in Sweden or something but I can't find the link unfortunately. I wouldn't want to put ball diffs through some crazy speed either.
I changed to the metal gear diffs. They're pretty heavy! Metal gears inside the diff, metal outdrives,metal bevel and crown gears in gearbox, metal gear box transmission outdrives ... the drive chain is bullet proof.
And for a 205mm wheelbase, you should be OK - might just need to move the washers on the suspension hinge pins so that you get an even shorter wheelbase.
#159
Cheers
#161
Cheers for the advice. I will look into it. Certainly the TOP R Sabre looks a well made car. I'm not keen on belt drive though. I'd also like to keep my whole setup under £200 to start with. I'll continue to read around it and see how it goes. I did find a vid of someone in US hitting 112mph (could have been kph, I'm suspicious) with a lightly moded m.rage haha. Slightly mad really as don't think it will last long!
Cheers
JJ
Cheers
JJ
Belt drives are fantastic. Mainly because of the motor orientation to the chassis. Much less torque steer from the motor allowing a more precise and even left to right throttle output punching out of a turn especially with these short wheel base cars.
The MRage is a fun little car no doubt. I think it is a super bargain. Everyone should have one.
#162
Hey no problem, JJ.
Thanks for the great advice everyone. Was a brilliant buy. You guys were right about bodies tho. Struggling to find a 170mm width 210wb. Want something aero which will fit the larger wheels!
#163
I had my M.Rage out the other day. I was having serious troubles with the car being extremely loose last Autumn, but it must have been a tire temperature problem. I installed swaybars after the first run (thicker up front, thinner in rear) and drove it again. It's much more planted now, though I can still upset the balance trying to slalom the car too quickly. Running a silver can motor and stock gearing is just right for this car.
#164
#165
I just pick up one. I can not wait until I get it.
