sanding diff ring or not w/ ceramic balls? >
Old 11-13-2005, 11:37 AM
dakrat's Avatar
Default sanding diff ring or not w/ ceramic balls?
is using a sanded (not polished) diff ring bad for ceramic balls? since the ring is rough, when the spur slips, will it damage the ceramic nitride balls?
dakrat is offline
Old 11-13-2005, 02:58 PM
I kinda doubt the diff rings will damage nitride diff balls.
Hyper1 is offline
Old 11-13-2005, 05:44 PM
dakrat's Avatar
i just sanded the rings and made them even shinier! lol i used the 800 grit sandpaper.
dakrat is offline
Old 11-13-2005, 10:14 PM
If your diff is slipping with ceramic diff balls, more damage is happening to the rings than the balls as they are harder than the rings.
jeffb is offline
Old 11-13-2005, 11:41 PM
Josh Numan's Avatar
Trader Rating: 26 (100%+)
You probably wont damage those balls to easily...
Josh Numan is offline
