Tc6.1 gearing
Old 12-22-2015, 03:44 PM
Propchecku37's Avatar
Trader Rating: 73 (100%+)
Default Tc6.1 gearing
Getting back into racing, just bought a used Tc6.1 going to run VTA using Tekin 25.5 and Tekin pro esc. Fairly large track, road course with 1 long straight away. Would like to convert from 48 and use 64 pitch gears but don't know where to start. Anyone who can point me in the right direction would be much appreciated.
Propchecku37 is offline
Old 12-23-2015, 08:58 PM
Trader Rating: 16 (100%+)
I'm running a 6.1 in VTA with a Tekin Pro ESC and Novak 25.5 motor. We run a medium size track and I run 48 pitch gears. I run a 72 tooth spur and a 40 tooth pinion. That gives me a FDR of 3.6. However, this weekend I'm going to gear taller with a 69/43 to see what that does for my straight away speed. Since you are going 64 pitch, my 72/40 would be a 96 tooth spur and a 53 tooth pinion.
glennhl is offline
Old 12-24-2015, 12:21 PM
Thanks glennhl, I was working with charts and figured on trying 96/48--96/51 and see what happens. Thank you glennhl for your help and Merry Christmas.
Old 12-24-2015, 12:40 PM
No problem. You will enjoy VTA with your 6.1, it's still a very competitive car! Have a wonderful Christmas.
glennhl is offline
Old 12-25-2015, 09:18 PM
YoDog's Avatar
Trader Rating: 28 (100%+)
you are actually in the range for a 17.5t with that gearing. You are going to want to be in the 3.0 - 3.4 FDR for a 25.5 motor. I run 96/48 in 13.5t on a medium sized track for example which is a 4.0 FDR. 90/54 will get you to 3.33 FDR which is more like a better starting point for the class you are asking about. Some clubs have a set FDR requirement for VTA and such so you might want to check that.
YoDog is offline
