3800mA batts charging with Turbo 35BL >
Old 11-12-2005, 10:06 AM
JLMG1971's Avatar
Default 3800mA batts charging with Turbo 35BL
My turbo 37BL charges my 3800s up to 2400s only at 6amps, at 0.3 cutoff, my batts get to only 99*F.... I am sure they are not peaking, the T35 is preprogrammed to go up to 2400s only, any way to bypass this for the new 3800 that normally charge up to 4100mA? Or should I need the new T35GFX?
I hope Comp. ELectronics have already looked into that...
JLMG1971 is offline
Old 11-12-2005, 11:31 AM
Company Representative
Danny/SMC's Avatar
Send it in to CE they can update the software. If your always near your charger while it's charging stop the charge at 500 seconds or more and then start it back up this will reset it for another 2400 seconds and give you atleast a 2900 second charge. The typical 3800s take 2600-2700 to charge. Make sure your peak detect is set at .02 - .03 not .30.
Good Luck.
Danny/SMC is offline
Old 11-12-2005, 01:36 PM
JLMG1971's Avatar
Danny thanks for the quick answer. Do you know if I order the eprom upgrade from CE, (as they have the option of ordering online) is it easy to install it? Is it software 5.70 that needs to be intalled in the T35 for it to charge 3800s?
Jorge
JLMG1971 is offline
Old 11-12-2005, 07:55 PM
Danny/SMC's Avatar
Call CE and ask for Jim he will tell you what needs to be done.
You can have it updated but by stopping the charge 500 or more seconds into the charge and restarting it will get a full charge. You can also go up to a 7 amp charge rate which should bring down the charge time to 2200 seconds.
