Gizmo GZ1 -
#811
I had a chance to watch the Gz1-Hg. Larry Myers had officially becone the only 2nd driver(durning a timed race, not practice) to break into the 14's in 17.5. Mike Gee was the only other. This car is just incredible on high grip. As our grip came up the car just kept getting faster.
Congrats Christian on the new high grip conversion. You nailed it!
#812
Thanks Joe!
I think Toastie did 14.9 at the warmup in A1 as well. So, he's the 3rd person to do it, but still, it's some elite company and it is someone that is not me. Which for me is very reassuring. One thing for sure is that there has not been as much traffic as the warmup so the track has not been quite as fast as it was then.
A month ago at the warmup we were struggling to keep up, and now we seem to have closed the gap. Our set ups are still not quite right either and both Larry and I feel like we are leaving a couple of tenths on the track that we hope to pick up by nats. I am super excited for sure!
#813
I really like the latest update to this car - looks much much better to me. More durable and easier to adjust but still a Gizmo. Ultra low CG and superior balance... speaking of CG, I would be tempted to run the ESC on the battery side in order to eliminate the issue of running the motor and battery wires so high up in the air - a universal problem. Should be easy with the little tiny spec ESC's from Hobbywing. I doubt balancing would be issue with the amount of added weight required on this car. Lowering and shortening the wiring is far more significant than most other CG lowering efforts by manufactures.
#814
#815
... with some modification. If the battery could be moved forward a bit, change the battery holder, fan could be angled off behind the motor - it's doable.
#816
Point being that it's almost impossible to achieve low CG wiring on standard touring cars and motor/battery wire is sooo heavy. Giant solid "lead" hoses flopping around way above everything else - drives me nuts. But on the GZ1 - very doable.
#817
Even without rotary shocks, due to the motor being much lower, using more ballast with a lighter battery, lower wires - CG should be lower than the Awesomatix - easilly.
#818
Also with the balance of the car coming into play if you move that 40+ grams over on the battery side, it will likely not balance until you hit 1400+ grams.
#819
ESC is 28g and wire length is less than half so that's sounds about right. Maybe only 1380g USGT weight is achievable but that would still be pretty awesome.
#820
#821
No. Hadn't seriously considered the Gizmo until this last update.
#822
Hmm, does the GZ1 match the Awesomatix or Xray mounting holes/wheel base etc.... just wondering if the precut bodies from Montech and Bitty are a direct fit?
#825
I'd have to wait for the latest full kit release with all the high traction conversion bits. It's a brilliant design but I didn't fully dig it until this latest update. Hopefully I'll have my Mugen before then to keep me busy.
