Team Associated TC7 & TC7.1 Touring Car
#1162
I ended up up reaming out the holes in upper deck very slightly. Also discovered some of the bolts which came with kit to bolt the bulkheads to chassis had heads that were not very true. When they would tighten up in the chassis they wanted to pull the bulkhead ever so slightly to one direction or another. Now it feels like all the tweak is gone.
#1163
alright running a tc7 17.5 box stock med/high grip asphalt went from blue fronts to grey front springs using rush 32x tires. The steering was too twitchy and over steering adjusted some exp in but didn't do much. Probably going to put the blue front springs back on. I glued the fronts on the inside half of the tire rears full coverage. Rear end stepped out at times but seems like it can controlled by making adj to the front of the car. What do you think?
#1164
#1165
Running new TC7.1
Ran the car this weekend and it was a learning curve for the driver. The car is faster than the driver but I will catch it. Ran it box stock and it was twitchy in the corners. We run on the new CRC black carpet.
I was thinking about gluing the front tires and maybe going from 3000 to 6000 in gear diff?
Also asked this earlier with no answer, does anyone use a servo saver and which one?
I busted a expensive futaba 571 on a not very hard crash.
Thanks and God Bless
#1167
stock setup is for asphalt. def get the xray servo saver, that's a must
#1168
If the aluminum chassis is in your sights, I would pick that up next...and increase ride hight to about 5.5 depending on layout....
and if servo saver is needed...look at the AE servo saver...Ive run these for years and they hold up very well...
https://www.teamassociated.com/parts...ts&query=25584
try these things first before making alot of changes all at one time
#1169
The bulkhead A/B caps move the towers farther out. I have a set of towers that produce the same shock height but fit on the old caps, the car is better on the new caps.
I tried two screws on the original 7.0 towers/long shocks with the new caps on a bumpy track this last weekend, it was really good but decided to go back to full 7.1/SMJ. I don't think we're going to find the old setup being faster anywhere if this track didn't show it.
