Team Associated TC7 & TC7.1 Touring Car >
Like Tree382Likes
Old 09-28-2019, 05:59 AM
  #3136
proliteandsc's Avatar
I drilled a hole in my carbon chassis behind the motor.
proliteandsc is offline
Old 09-28-2019, 04:13 PM
  #3137
boudin4evr's Avatar
Trader Rating: 18 (100%+)
Originally Posted by tony q View Post
I have the aluminum chassis thereís 2holes behind the motor so I use a servo mount to hold the fan and mount it on the chassis
Pics?
boudin4evr is offline
Old 09-28-2019, 10:35 PM
  #3138
tony q's Avatar
Trader Rating: 14 (100%+)
Originally Posted by boudin4evr View Post
Pics?
hereís the pics
boudin4evr likes this.
tony q is offline
Old 09-29-2019, 10:36 AM
  #3139
I'm running a protoform 69 Camaro body on my 7.1. Anyone know how wide the HPI camaro is at the front wheels. We can use rear wheels on the front, but they don't fit under the protoform body. I know HPI is a 200mm body and Protoform is 190mm. Protoform is 7 3/4 at front wheels. Any VTA bodies out there wider?
Old 09-30-2019, 11:11 AM
  #3140
3TurnRacing's Avatar
What is the preferred Body for 17.5 TC on a new Black CRC carpet Track rollin on Gravity RC G-Spec Type C rubbers. Any ideas?
3TurnRacing is offline
Old 09-30-2019, 11:28 AM
  #3141
theproffesor's Avatar
Trader Rating: 62 (100%+)
Have you looked to see what everyone else at the local track is running? Thatís a good start.
eR1c likes this.
theproffesor is offline
Old 09-30-2019, 12:23 PM
  #3142
Yes and no! Our track is being laid as we speak with the opener being around the 20th of October, so its a fresh track. I've tried to look at various other similar tracks, so I thought I'd reach to you guys
Old 09-30-2019, 12:31 PM
  #3143
The Type S, Zooracing, bitteydesgin montech racer all of them work most of the bodies out there will work. set up wise start with kit set-up for black crc carpet. Kevin's snowbirds set-up is a really good starting point also.
racer034life is offline
Old 09-30-2019, 12:51 PM
  #3144
Now that ZooZilla looks perfect.
Old 10-06-2019, 05:55 AM
  #3145
Guys, what to look for if I want to see the difference in TC7 and 7.1 please.
Thanks.
jojji22 is offline
Old 10-06-2019, 06:44 AM
  #3146
jpx
jpx's Avatar
Thanks.
Main step from TC7 to TC7.1 was shorter shocks and with that different shock towers and upper bearing caps.
glennhl and jojji22 like this.
jpx is offline
Old 10-06-2019, 09:19 AM
  #3147
Trader Rating: 58 (100%+)
I’m running a tc7.1 in 21.5 usgt. Am I better off using the graphite chassis or the aluminum?
Thanks in advance!
sweetride4me is offline
Old 10-07-2019, 07:45 PM
  #3148
Originally Posted by sweetride4me View Post
Iím running a tc7.1 in 21.5 usgt. Am I better off using the graphite chassis or the aluminum?
Thanks in advance!
Graphite on asphalt.
Aluminum on carpet
sweetride4me likes this.
