Team Associated TC7 & TC7.1 Touring Car
#1562
Happy new year. got some money for x mas so i put it in my car got alum chassis floating steering and dcv kit and steel outdrives is this a good start to a 7.1 please let me know if the setup is a tc7 or a tc7.1. i should put on. black carpet. we run on. i have the car all apart os now the time to put a good setup on.
Maybe look at keven heberts (mod) and Eric epps (usgt) setup sheets from MHIC at 5280 . Both ran the 7 with aluminum chassis.
http://site.petitrc.com/reglages/asso/SetupsheetsAssociatedTC7.html
#1563
Ur car looked pretty dialed, I'm curious how u will like the alum chassis.
http://site.petitrc.com/reglages/ass...ciatedTC7.html
#1565
Do you or anyone else have a pic of how the AE strap kit fits on a TC7? I'm just wondering what it really takes to get it to fit. Are we talking about a tiny notch in the front bracket?
I've literally been using strapping tape from the hardware store and while it works fine, I'd rather deal with velcro.
Matt
Matt
#1566
Spare parts
I'm just getting my feet wet into on-road. I've raced off-road for years. I picked up a TC7.1 and plan on racing TC. What are the most needed spare parts I should have on hand? My local hobby shop does not stock any parts for the TC cars.
#1568
#31677 hinge pins are needed by most at some point
#31633 dcv rebuild kit is nice for the pins and rings since they're somewhat unique
With zero local support, if you want to be sure you can stay at the track.. You probably want a second car with you. I typically race two and have 1-3 sets of spares. If you're ok going home early, the parts are in stock at many online retailers so you'll be good by the next weekend and your local shop is near guaranteed to have an account to order AE parts for you fast.
#1569
The tc7.1 shocks were excellent in my tc4, and I never traction rolled for the first time ever... The lowered CG helped alot with the 60g blitz body... All I need to do now is practice more, and get my motor game up....
#1570
64 pitch spurs that fit
Whats up all!!!
So I've read the first 40 pages of the thread and I've exercised the search function so now I will ask the experts. Picked up a car recently and was wanting to use my 64 pitch spurs from my other car. Seems my spurs are a bit thin and cause the hardware to push through the spur hub clamp assy. So, try shorter screws, well then the teeth on the clamp that engages the spur pulley are too log leaving a gap on one side to the pulley. Thought about shims or washers on each side of the pulley but then you have all that weight spinning around on your pulley. What light weight 64 pitch pulleys are you guys having luck with?
Any input is appreciated!!
Kevin
Kevin
#1571
I've got a Xray spur gear in mine. I just used shims the get all the spacing right. Your not really adding weight if your running a narrower spur gear with small shims rather then a thicker gear that doesn't require shims.
#1572
Rob,
Thanks for getting back to me, that Xray spur, that's the offset one correct?
#1573
Sorry about the double post the first attempt, I thought, didn't go through
#1574
