24mm or 26mm tire width ? >
Old 11-11-2005, 06:20 AM
Default 24mm or 26mm tire width ?
Hi,
OK, I know that the 24mm tires are by far more popular for 1/10 electric cars
But on the TCS they are both allowed.
Which one of these two will be more efficient for better lap time ?
I know that the 26mm are bit heavier, but they should provide more grip.
Danke
e_lm_70
e_lm_70 is offline
Old 11-11-2005, 06:25 AM
26mm tires scrub speed due to the increased surface area
Dodgersfan is offline
Old 11-11-2005, 09:17 AM
24s....No doubt...
26 also makes the car too stable..
Ben.C is offline
Old 11-11-2005, 05:22 PM
Super Moderator
Grizzbob's Avatar
Also, depends on the tire you need, some may only come in 24mm, like the newer Type B3's(haven't heard about them in any size but 24mm). but in general, I think you'll like the responsiveness of your car most with 24mm all around(they really don't give up much grip at all, & they seem better rolling through corners to me)...
Grizzbob is offline
Old 11-19-2005, 04:56 PM
slippery49's Avatar
I Run 30mm on rear and 26 mm on front
slippery49 is offline
Old 11-22-2005, 09:42 PM
calstarjig90j's Avatar
On electric? I thought those are more for nitro.
calstarjig90j is offline
Old 11-23-2005, 04:32 PM
Super Moderator
Grizzbob's Avatar
Actually, those tire widths in 1/10 scale electric sedans is for foam tires only, you will not see rubber tires at any width beyond 24 or 26mm(except for bigger scale cars or some nitros).....
Grizzbob is offline
Old 11-23-2005, 08:39 PM
Rod M's Avatar
I have done this with foams with my Xray, works pretty well in mod,
Rod M is offline
