Useful Stuff to Know: AMB Personal Transponder Durability >
Old 11-11-2005, 10:22 PM
  #16
ogreasurada's Avatar
Originally Posted by asw7576
Hahaha, microsoft things
Anyways, how come no one seems to use the new system that Orion released a while ago?
PS: Thanks for Soviet for the testing.
ogreasurada is offline
Old 11-12-2005, 07:22 PM
  #17
BrentL's Avatar
can you run more that 1 car on the orion LCS?
BrentL is offline
Old 11-12-2005, 08:18 PM
  #18
RC Scoring Pro's Avatar
Mine must be defective, I only got 113 turns before it broke
RC Scoring Pro is offline
Old 11-12-2005, 08:19 PM
  #19
Soviet's Avatar
Surely you jest!
Soviet is offline
Old 11-13-2005, 10:08 AM
  #20
Default Improved PT
So would any of you guys like an improved clone of your own PT or are you happy with what you've got?
... 114 turns, 113 turns why not fit a new lead yourself!!
andsetinn wants his 1234567 I know
Terry_S is offline
Old 11-13-2005, 10:33 AM
  #21
Terry, if you're going to build transponders. Why not build whole AMB compatible system? Half the work must be already done.
andsetinn is offline
Old 11-13-2005, 10:50 AM
  #22
Soviet's Avatar
Good luck cracking the case on one of those!
Soviet is offline
Old 11-13-2005, 11:28 AM
  #23
Possible to do but... all the clubs have AMB and won't change.
Soviet, PT number 1234567 not 1234567 turns on the lead!
Terry_S is offline
Old 11-13-2005, 04:07 PM
  #24
Sorry, but there is no transponder with the #1234567. The lowest number is 2097152.
Old 11-13-2005, 11:27 PM
  #25
Josh Numan's Avatar
Trader Rating: 26 (100%+)
WOW!
Josh Numan is offline
Old 11-14-2005, 01:06 AM
  #26
RC Scoring Pro. There will be when I get my MRT Personal transponder.
Didn't AMB say that there were 9999999 possible transponder numbers?
Terry. If the system is fully compatible with the AMB one, the clubs that don't have AMB system, or have AMB20 and want to upgrade, would look at your system. AMB system is good system but the system and service is very expensive. Lot of smaller clubs are desperate for smaller system.
Old 11-14-2005, 01:14 AM
  #27
Josh Numan's Avatar
There are actually easy numbers made just for some special drivers......Some that i belive work there.
  #28
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Next test: Deans Wet Noodle vs. Novak Super Flex
Who will win in this epic battle of the wires???
Randy Caster is offline
Old 11-15-2005, 05:36 AM
  #29
Didn't AMB say that there were 9999999 possible transponder numbers? .
Yes and you said you have #1234567, so I guess you don't have it??
There are 9999999 possible numbers, it appears 1234567 isn't one of them!
I agree. If there are a lot of smaller clubs desperate for a smaller system I'd like to hear from them. New clubs especially start off small and to grow need affordable equipment, the trouble is pc's are cheap but autocount is expensive.
Terry_S is offline
Old 11-24-2005, 07:28 AM
  #30
RE PT wires:
I, and many others have somtimes wondered how durable the wire itself is. Because many of us only own one Personal Transponder and transfer it from car to car. Thats alot of binding, twisting and stuffing. Wouldn't it suck if the wire broke internally???
Of course it would.
So I took a single wire, stripped it of insulation and grabbed ahold of it with two pairs of pliars. Spinning the wire in opposite directions, I got up to 114 turns before the stuff broke.
So there you have it. While your wire may look like a kinked and twisted mess, know that the wire inside is:
A) VERY flexible
B) Extremely strong
Sleep well knowing that the wire inside your AMB Personal Transponder is very tough yet flexible stuff.
(P.S. - That was alot just to say that the wire is strong eh?!?! )
Anyone broken their AMBrc PT lead/wire after all that twisting? If you have MRT can replace and fix the leads
Terry_S is offline
