Sedan Hex & axle. Seeking help. >
Old 11-10-2005, 03:18 PM
oXYnary's Avatar
Default Sedan Hex & axle. Seeking help.
Does any manufacturer who uses the standard 1/10th hex rim use a 3mm axle? Failing this does anyone know where I can get some brass or other tubing thats 1mm in thickness. 4mm for the outer, and 3mm for the inner.
oXYnary is offline
Old 11-10-2005, 08:15 PM
seaball's Avatar
i don't think you'll find axles that small in 10th scale. for the tubing try here:
www.mcmaster.com
seaball is offline
Old 11-11-2005, 05:18 PM
oXYnary's Avatar
Not even tamiya minis? Argh! Thank for the link though it does look like that is a commercial outlet versus a public (IE bulk).
oXYnary is offline
