Old 11-10-2005, 12:32 PM   #1
thecrow2k's Avatar
Default Pulsar Discharge
Ive hooked my new pulsar competition up to a 12v battery. I started to discharge my batteries, the cutoff is set at 5.4v but both packs cut off at about 7.3v I think. Any thing Im doing wrong?
thecrow2k is offline   Reply With Quote
Old 11-10-2005, 02:21 PM   #2
thecrow2k's Avatar
Its discharging now properly, but my batts are reading on the 10a discharge just 2900mah and there matched 33's, is this common and will the numbers increase after charging and discharging process?
Old 11-10-2005, 03:09 PM   #3
TadehI's Avatar
Yes, Invest in some bulbs or a high tech discharger such as Spintec or Dyna Pulse, both are very good. The problem with the Pulsar is that it does not dischrage at what a motor under normal use would discharge at so you are left with a high Internal Resistance(IR) But this is only if you do it for a very long time (Many Discharges).
TadehI is offline   Reply With Quote
Old 11-10-2005, 03:30 PM   #4
thecrow2k's Avatar
Would something such as a dynapulse coupled with a discharge tray give me higher runtimes and better IR?
Old 11-10-2005, 04:17 PM   #5
Pat Clark's Avatar
Yes a Dyna Pulse with a tray such as Absolute Zero will lower IR, and gain voltage.. and may pick some run time being that pack will be equalized before charging
Associated, Reedy, Tekin, Tq Wire, Protoform, Veytrec Design Lab
Pat Clark is offline   Reply With Quote
Pulsar 2 , Novak Discharge Tray , Indi Reactor , Cobra lathe , OS 2050 Pipe turd ferguson R/C Items: For Sale/Trade 16 03-30-2008 10:02 AM
LRP PULSAR 1 CHARGER IN GREAT SHAPE WITH TRINITY DISCHARGE TRAY DENNIS STORTI R/C Items: For Sale/Trade 3 08-06-2007 09:04 AM
motor lot, lrp pulsar competition, discharge tray, spring dyno, indi torpedo: CHEAP billjacobs R/C Items: For Sale/Trade 8 11-02-2006 11:08 AM
LRP Pulsar Charger, Integy discharge Trays, Servos, Tekin G10 speedo barnacle R/C Items: For Sale/Trade 15 10-07-2006 09:59 PM
lrp pulsar discharge pink pac man Electric On-Road 17 11-03-2004 01:13 PM
