Like Tree1Likes
Old 11-24-2015, 07:33 AM   #1
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Default the new CRC carpet opinions
We are looking to get some on our track .
But thunder has snowbirds level traction for club racing with only 10 people running ,without spraying the track
jlfx car audio is offline   Reply With Quote
Old 11-25-2015, 07:32 AM   #2
dave-man's Avatar
Trader Rating: 17 (100%+)
We just put the new stuff down a couple weeks ago. (Summit RC in Fort Wayne, IN) The new stuff is everything Frank says it is. We are very pleased with it. Amazing traction and virtually zero fuzz.
dave-man is offline   Reply With Quote
Old 11-25-2015, 08:12 AM   #3
Trader Rating: 20 (100%+)
I assume this means that CRC has changed their carpet or is offering two versions now?
Is this the same or similar to the ETS carpet?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 11-25-2015, 09:40 AM   #4
Cosmo's Avatar
What tires are the 1/12 guys running on the new carpet?
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 11-25-2015, 11:14 AM   #5
Amazing compared to what (normal/birds/iic/club race?)
If their was 400 cars running 1k laps each with traction continue to build
Old 11-25-2015, 12:07 PM   #6
Austintown Hobby Raceway just put in the Fastrack II carpet and we've been running practice for two weekends now. In 17.5 1/12th, we've been using mostly CRC/BSR blue front and rear. Double blue fronts work as well, but maybe not quite as fast. Team purple/spec lilac fronts work as well.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 11-25-2015, 12:10 PM   #7
Drew Manzella's Avatar
Trader Rating: 29 (100%+)
What I have heard is that the same tires work on it BUT the prep/sauce is minimal to completely not needed.
I of course have zero experience with it - this is just what I have been told.
Drew Manzella is offline   Reply With Quote
Old 11-25-2015, 12:45 PM   #8
I was only saucing maybe a 1/4 or less of the front blue tires, and the steering was pretty aggressive on the first couple of laps. Once the tires set in, I could still lift or flip the car if I drove really hard into a turn on too tight of a line and cranked the wheel. I kept taking caster out of the car all day and ended up at min caster on the front of my S120LTR. Next I want to try different upper arm mounts with less degrees of active caster. 0 active caster blocks may end up being my favorite, then I can dope more of the front tires and not have to worry about lifting.
Old 11-25-2015, 01:21 PM   #9
"snowbirds level traction" - I think that will be redefined this year with FT2.
On that subject, while Snowbirds great car count always builds excellent traction, I wouldn't label Snowbirds as the pinnacle of high grip. The track changes between oval and road "disturbs" the carpet fibers reducing the traction potential. This is a non-issue as the grip is always great at the Birds, however other large events can see even higher levels of traction.
Team CRC is offline   Reply With Quote
Old 11-25-2015, 03:14 PM   #10
If their was 400 cars running 1k laps each with traction continue to build up even higher ?
Old 11-25-2015, 04:28 PM   #11
cwoods34's Avatar
Aggressive TC setups were violently traction rolling the first night of club racing. It also felt really consistent throughout the evening.
cwoods34 is offline   Reply With Quote
Old 11-25-2015, 05:23 PM   #12
ShaunMac's Avatar
This carpet could spawn a new line of harder spec tires.
ShaunMac is offline   Reply With Quote
Old 11-25-2015, 05:26 PM   #13
Like, say, USGT tires for all tc classes? But with real inserts.
Old 11-25-2015, 09:31 PM   #14
IndyRC_Racer's Avatar
Coming soon...crc tires that work on their new carpet.
I never understood people wanting such high bite carpet.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 11-26-2015, 06:37 AM   #15
Not sure if higher grip was an intended outcome, or if they were just aiming for longer wear, more consistent traction, and even less fuzz. I do know that, if dark blue and black are a big part of your paint scheme, you're gonna have to change it!
