New Ride Formula 1 tires
Hello everybody,
I feel that the new F1 Ride rears are not holding the grip very long. After 4 battery packs they loose their grip, and after the 7th pack they are nearly undrivable. Unlike the old ones, which hold the grip forever and had much better overall tracktion. I run them on carpet using CS high grip. Any of you has the same Problem? The new front tires are great, much better than the old ones. Over all I have to say that the quality ist better as the old ones, but still not good. The trires are still very unbalanced. I |
Originally Posted by florianlaux
(Post 14270405)
Hello everybody,
Only rears....fronts are great
I know the guys at our track (outdoor asphalt) like them a lot. We are making them our informal spec tire for F1. I am still burning through my current set of Shimizus before buying some Rides.
Originally Posted by funked1
(Post 14270694)
Also what additive are they using. |
Originally Posted by Skiddins
(Post 14270747)
And are they lasting a good few runs without issues?
Also what additive are they using. and fx2 or lrp asphalt, clean with buggy grip |
Yes i am talking about the ETS 2015 tires
I have used XR for two full races now. They are smaller diameter than R1. On the track the front XR are better than R1 and the rears, I would say, are the same. The XR are a bit better balanced than R1 but far from perfect. The best part is the XR rears do not tear as easy as R1. I had to glue the R1 every second run.
The balance of the tires is near the 571/572 shimizu with a little more understeer. All this on carpet with LRP Carpet Grip 3. |
Did you run the same set for the 2 races?
AT the meeting I ran at on carpet I ran the R1's and also Pit 575/575 combo and the prebuilt GRP's (the current control carpet F1 tyre for BRCA events)
The Rides were the slowest of the three, but only just. This was on Prima carpet. |
(Post 14270913)
Why wouldn't you run them on carpet? What's you line of reasoning?
Originally Posted by JayL
(Post 14270816)
Yes, very consistent, but he is talking ETS spec version before the new XR. The XR have only been run locally once and they are crazy good on low grip. I would never use them on carpet
too soft imo
I will have both version of the ride and usual pit for 209 the 12th so will see :) |
ok cool.
That sounds like dirt buildup... Make sure you use a cleaner that does not dry the tires, and wipe off the excess traction compound very well... Also, the carpet track will need to be vaccumed well every day to prevent buildup...
