Muchmore Fleta Pro Firmware
I'm going to use my TC briefly for at super stock race (no timing in esc / timing on motor allowed).
I have previously used the Expert 1.3 firmware for mod racing.
I can see, when I hook the esc to the computer, that there is a Blinky 1.3 and a Stock 1.3 firmware.
What is the difference?
I have loaded the Stock 1.3 firmware into the esc, recalibrated the radio/esc, set all timing options to 0, and the green light flashes when in neutral. It all seems OK and everything works.
What is the Blinky 1.3 firmware? The same as the Stock 1.3, but with no options to set timing?
Thanks!
Thanks!
Yes if you change the settings it will stop flashing. It allows you to run both without having to flash your firmware.
Hi I have been using the pro for just under a year and two things I found when u put it to blinky on ur pc u need to do a esc reset on the programme car or u have boost u can't get rid of
Also test it ur self but I found 1.1 is better then 1.3 as 1.3was made smoother for mod which is to smooth for Blinky
One guy went 0.3sec a lap quicker with 1.1
