Old 11-08-2005, 02:57 PM   #1
Merciless's Avatar
Send a message via ICQ to Merciless
Default Integy 16X9 V6
Hopeing someone might be able to help me here,
I got the above charger and for the first time have recently tried using it to charge 4 cell packs for my 1/12th car.
I set the peak to 3mv which is as low as it'll go , told it it's charging 4 cells , a 5amp charge rate and 3300 as the battery capacity.
But it dosen't seem to ever reach the fallback and cut-off .The batteries will get very hot and even vent if left long enough ....
I think whats causing it is the pauseing between the charging phases where the voltage will drop off momentarly before the charger cuts back in again.(the charger seems to have a 5sec non-charging gap about every 45sec's)
Is this the super linear pulse ?? (crap if you ask me)
Merciless is offline   Reply With Quote
Old 11-08-2005, 07:33 PM   #2
POOKYT's Avatar
I have the older 16X9. Do you have the cell type of NiMh set as well? If its on NiCd it will get the cells too hot. Hope this helps.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 11-09-2005, 04:32 AM   #3
Merciless's Avatar
it's set as NiMh but cheers for trying,
I feel sure it's the pulse charging thats doing it as the cells volts drops back everytime the charging cycle is broke , when it get's to where i feel the charger should cut out ( cells charged ) it cuts out and the volts drop back on the next charge cycle it only just about gets the volts on the cells back to where it was before the last off cycle before cutting out again
Old 11-09-2005, 10:48 AM   #4
TVMRocket69's Avatar
Send a message via AIM to TVMRocket69 Send a message via Yahoo to TVMRocket69
Hello, I have the same charger. And mine does the same but only 1 pack vents. My batteries at the most get about 3 to 5 degree's hotter than they should be but my packs are over 2 years old and I charge at 5.5amps with a cutoff of 5mv/cell. The way it charges if U compare it this charger acually puts more in the cells. I compared it to my Pulsar Comp and the Quasar Pro I have. I have 1 pack that takes over 4000mah with this charger. I am also using Pro-Match batteries right now. I really don't think it's the charger, but if U feel it is U can always goto integy web site forums and ask Arthur about it.
Bob
Bob Walker Jr.-Sponsor's-
AnswerUSA-RC Team Driver, G's R/C Raceway Team Driver, RBMods Team Driver, Kosmic R/C Fuel Team Driver, MurfDogg Motorworks Team Driver, Serpent S811B, Serpent S811t, MurfDogg Powered V-Desizn Carpet Ripper 5
TVMRocket69 is offline   Reply With Quote
WTB integy 16x9 v6 TeckLancer R/C Items: Wanted to Buy 0 11-23-2007 09:46 PM
Integy 16x9 v6 superjet701 R/C Items: Wanted to Buy 1 03-06-2006 07:45 PM
Integy 16x9 T Stephens R/C Items: For Sale/Trade 0 06-06-2005 02:09 PM
integy 16x9 f/s Jarrod Langlois R/C Items: For Sale/Trade 5 12-16-2002 01:05 PM
Integy 16x9 37 RACING R/C Items: For Sale/Trade 1 12-12-2002 10:18 PM
