Hobbywing
Old 11-03-2015, 07:01 PM
Default Hobbywing
I have a Hobbywing esc that steering work but no throttle what could it be
Bryantodd is offline
Old 11-03-2015, 07:05 PM
Maxxican's Avatar
Trader Rating: 67 (100%+)
is the ESC plugged in correctly to the receiver?
have you tried a different receiver?
did you calibrate the ESC?
Maxxican is offline
Old 11-03-2015, 07:25 PM
You may also try reversing your throttle channel. Some ESC will not calibrate if the signal is not the right way.
Martin Paradis
rhodopsine is offline
Old 11-03-2015, 07:41 PM
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Trouble shoot by trying to calibrate the esc in another known working vehicle. If it still won't function try resetting a model on your radio to factory specs, as well as the esc.
andrewdoherty is offline
Old 11-04-2015, 04:19 AM
Trader Rating: 23 (100%+)
could easily be the sensor wire as well
phatboislim is offline
Old 11-04-2015, 04:55 AM
I believe that all Hobbywing esc's default to sensorless mode if there is a bad sensor cable. Just lower power and cogging at start but motor will still run.
old_dude is offline
