Old 10-15-2015, 01:31 AM   #1
howardshum's Avatar
Default What is the commend of this radio
Dear All
What is the commend of this radio?
howardshum is offline   Reply With Quote
Old 10-15-2015, 11:05 AM   #2
I have had that radio for the past year and I really like it. It uses only 4 AA batteries and my battery life has been at least 6 months with probably 90 four minute heats. It is comfortable to hold, balances well in my hand. It is also very easy to program and has all the settings you need to run a touring car....EPA, Expo, Dual Rate, 10 model memory.
The only negative I can list is that the receivers are proprietary as far as I know and they cost $50 each. I now have 6 receivers so that can add up pretty quickly.
glennhl is offline   Reply With Quote
Old 10-15-2015, 10:24 PM   #3
howardshum's Avatar
Thanks!
This radio can use sanwa other servo receiver?
Old 10-16-2015, 11:06 AM   #4
Airwave's Avatar
This sentence means no...
Airwave is offline   Reply With Quote
Old 10-17-2015, 08:11 PM   #5
howardshum's Avatar
Anyway is it have two version? Watre proof?
Old 10-17-2015, 08:27 PM   #6
The receiver that comes with it is waterproof (rx-37)
speed_dmon is offline   Reply With Quote
Old 10-18-2015, 10:07 AM   #7
Thanks!
These are the two cheapest receivers I have been using with success. They are made by Sanwa/Airtronics. I believe Sanwa makes all Airtronics electronics.
RX371W (Waterproof 3 channel receiver) part no. 92621 or 92622
RX371 (3 channel receiver) part no. 92524
These are FHSS-2 compatible. They both cost $50 to $60. If someone finds a cheaper alternative, please post.
Old 10-18-2015, 11:06 PM   #8
howardshum's Avatar
So, do you have this Sanwa new radio? Can you share your comment? Since I am thinking to order. Thanks!
