Awesomatix A800/A800R >
Like Tree2314Likes
    Hide Wikipost
Old 03-29-2023, 11:28 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800/A800R
Last edit by: hanulec
A800R Released March 23, 2023 with two kit versions, A800RA (alloy) and A800RC (carbon)
Mid Motor Content ---
New Part Releases
  • January 2020 - A800-AM24-20 Servo Holder - combine servo holder and steering holder to one single part.
  • February 2020 - A800-ADC Advanced Damper Cup Set - Reduces the amount of rebuild routines. It offers the possibility to A) remove air and B) add oil into the damper without the need of full disassembling
  • January 2021 - A800-BDL - Body Downtravel Limiter, replaces SPR08
  • March 2021 - A800-P138LFA - 38T Pully Low Friction - For Gear Diff
  • March 2021 - A800-P138S-LFA 38T Spool Pulley Low Friction - For Spool
  • April 2021 - A800-C27MMX - Full Length Top Deck for A800MMX
  • May 2021 - A800-C01MMA Alloy Chassis - Battery position is shifted to the front to achieve a better overall weight distribution. Removes short arm holes. New narrower shape
  • September 2021 - A800-C04M1+7.0 Arm - narrows the track width for lower grip levels
  • October 2021 - AM180EVO Single Bellcrank Steering Update - AM180EVO is a direct replacement for AM180M5
A800MMX and A800MMXA Kit Updates
  • AM152/AM24-8 is replaced by AM24-20 in this kit (UPDATE 08.03.2021)
  • P138/P138S is replaced by P138-1/P138S-1 in this kit (UPDATE 25.03.2021)
  • C01B-X-MMA is replaced by C01MMA in MMXA kit (UPDATE 26.05.2021)
  • AM180M5 is replaced by AM180EVO in this kit (UPDATE 21.09.2021)
Below OLD Rear Motor Content ---
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 06-11-2024, 08:07 AM
  #6856
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Originally Posted by dameetz
Hi everyone, I m interested in getting the A800R carbon version. I will be running this on a low to medium grip tarmac local track. My questions are, is the option progressive springs are a must ? So far i ve included the multitools and caster doodle in my cart, what other parts or option parts do you guys suggest to get? Thanks.
Recommendations can vary based upon tires and motor class
1pc top deck c27mmx
G10 split top deck from AwesomatixUSA
15% and 25% PSS st69 parts
Am23-1
Am19-ltl
Long upper links (at25-2)
Longer st24
Shims
hanulec is offline
Old 06-11-2024, 10:13 AM
  #6857
hana166's Avatar
After four years recovery from the plague I have finally done a few meetings with this car which I built years ago, after a difficult start it seems to be able to keep up quite well.
hana166 is offline
Old 06-13-2024, 11:05 AM
  #6858
Team EAM
Trader Rating: 79 (100%+)
Originally Posted by hanulec
I cannot believe alloy chassis are selling during the summer
There were a whole lot of alloy chassis being ran on asphalt at the ETS this past weekend....in all camps! Especially the winner of Mod that says he ran Carbon on his setup sheet.....
EA
EAMotorsports is offline
Old 06-13-2024, 11:17 AM
  #6859
EA
congrats on da win EA !
hanulec and Raul1991 like this.
Ggrant is offline
Old 06-13-2024, 02:01 PM
  #6860
h2e
h2e's Avatar
Can you elaborate on the difficulties you encountered?
h2e is offline
Old 06-14-2024, 02:38 AM
  #6861
hana166's Avatar
The mass centralisation makes the car ultra responsive. Particularly the removal from the front. I tried the old car just to compare, with long lipo, and it's night and day. Motor position also makes the car rotate very easily also, which perhaps might not be desirable in certain circumstances such as low traction. I wanted it in the middle because it acts like a spinning gyroscope and I wanted the effects to be the same front and rear. Not sure it really matters or works, maybe, maybe no.
And today's shells are ultra aggressive compared to four years ago, so slowing down the steering response and generally calming everything down was a priority, as well as finding an acceptable body position as I have no experience at all with the modern bodies, which are ultra light. I used an Xtreme Twister with carbon support which seems well balanced (but super aggressive) but previously I was on a 2019ish Protoform Type S which is calmness personified. Also everyone has gone down to 17.5. I will build a mod car also when I get a bit of time, perhaps the mass centralisation will make it kinder to the tyres, as it requires so little energy to initiate the turn.
I used the original baseplate, it is the best one they ever made because it has a rebate all along the middle which provides the perfect flex characteristic for someone like me, as well as lowering the C of G ..Under the battery I used super slim tungsten weights which fit in the rebate. The fan is high up, but I guess that at only a few grams it was better to keep the components in a compact arrangement to reduce moment of inertia. I've been out for years, I just thought it would be fun to play with the physics.
Lonestar, DavidNERODease and h2e like this.
hana166 is offline
Old 06-14-2024, 04:32 PM
  #6862
h2e
h2e's Avatar
Did you get a 50/50 weight split? and did running the front belt tighter help with oversteer?
h2e is offline
Old 06-15-2024, 08:58 AM
  #6863
hana166's Avatar
I definitely prefer 48F/52R rear 30g ish heavier without body as it reduces initial response although of course one gets more pendulum from the mid turn.
I run the front belt a bit tighter than the rear but next meeting I will try the front spool high as it is something I have never done in all my years racing.
Honestly I don't know what the effect will be.
Perhaps someone more knowledgeable could chime in on the subject.
hana166 is offline
Old 06-15-2024, 09:55 AM
  #6864
h2e
h2e's Avatar
In my book that is relatively tail heavy. I've had a 52F/48R configuration once on a similarly laid out car, and I got understeer. With a 50/50 or 49F/51R balance you should just end up with the right amount of steering, given the rest of the setup is relatively neutral, too.
Did you have any problems of the front belt jumping off in frontal crashes?
From looking at your pics it's not clear if you have any toe gain front or rear when the suspension compresses. On the setup station that would be easy to check. On my personal setup sheet it's noted like this:
Setup sheet notes on toe and camber gain under suspension compression...
*Note: I might close this sub-discussion, as it's more related to a DIY project than the A800 platform.
h2e is offline
Old 06-16-2024, 11:34 AM
  #6865
hana166's Avatar
hana166 is offline
Old 06-16-2024, 07:56 PM
  #6866
Regional Moderator
disaster999's Avatar
So I was taking apart my friends MMX and my 800R rear CVD to clean and re-lube. Per instructions, you take a 2.5mm flathead to spread the ST02 so you can take the ST16 out. On his MMX the ST02 permanently deformed and its spread too far apart. The ST02 on my 800R was able to return to its original shape. Im guessing the batch on the MMX is made with different material/temper and is softer? Good thing the way how the axles goes together for these cars, it still squeezes the ST02 together enough to capture the ST16 so the car is still able to drive.
disaster999 is offline
Old 06-16-2024, 09:55 PM
  #6867
BEMO2019's Avatar
I had similar happen to my old MMX. Probably a bad batch of tempering or I spread it too far. I just slid it back into the AT13 and never thought about it again.
BEMO2019 is offline
