Awesomatix A800/A800R >
Like Tree2314Likes
    Hide Wikipost
Old 03-29-2023, 11:28 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800/A800R
Last edit by: hanulec
A800R Released March 23, 2023 with two kit versions, A800RA (alloy) and A800RC (carbon)
Mid Motor Content ---
New Part Releases
  • January 2020 - A800-AM24-20 Servo Holder - combine servo holder and steering holder to one single part.
  • February 2020 - A800-ADC Advanced Damper Cup Set - Reduces the amount of rebuild routines. It offers the possibility to A) remove air and B) add oil into the damper without the need of full disassembling
  • January 2021 - A800-BDL - Body Downtravel Limiter, replaces SPR08
  • March 2021 - A800-P138LFA - 38T Pully Low Friction - For Gear Diff
  • March 2021 - A800-P138S-LFA 38T Spool Pulley Low Friction - For Spool
  • April 2021 - A800-C27MMX - Full Length Top Deck for A800MMX
  • May 2021 - A800-C01MMA Alloy Chassis - Battery position is shifted to the front to achieve a better overall weight distribution. Removes short arm holes. New narrower shape
  • September 2021 - A800-C04M1+7.0 Arm - narrows the track width for lower grip levels
  • October 2021 - AM180EVO Single Bellcrank Steering Update - AM180EVO is a direct replacement for AM180M5
A800MMX and A800MMXA Kit Updates
  • AM152/AM24-8 is replaced by AM24-20 in this kit (UPDATE 08.03.2021)
  • P138/P138S is replaced by P138-1/P138S-1 in this kit (UPDATE 25.03.2021)
  • C01B-X-MMA is replaced by C01MMA in MMXA kit (UPDATE 26.05.2021)
  • AM180M5 is replaced by AM180EVO in this kit (UPDATE 21.09.2021)
Below OLD Rear Motor Content ---
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 05-03-2024, 12:46 PM
  #6826
Trader Rating: 16 (100%+)
Originally Posted by trilerian
Finally got all my parts to put my car back together. Interesting discovery... I bought a set of arms, C204-S. I thought these were a direct replacement for the stock arms (well, I guess they still are). However the new version looks to be a little beefier on the leading side of the arms, in the front orientation.
Photos please of before and after.
glennhl is offline
Old 05-03-2024, 04:56 PM
  #6827
trilerian's Avatar
Trader Rating: 51 (100%+)
It isnít a big change. I only noticed because I was making sure the arm was the right length and put them back to back.
New arm is on the right.
trilerian is offline
Old 05-03-2024, 05:08 PM
  #6828
Did you measure them, I can hardly tell the difference looking at them.
glennhl is offline
Old 05-03-2024, 05:32 PM
  #6829
trilerian's Avatar
I did not measure it. I’m happy for the extra material…
Here is a pic with the arms stacked on top of each other. This was how I noticed it. To note, my car came from the 3rd batch of orders. So this may have changed awhile ago...
gwhiz, glennhl and Tom6440 like this.
Old 05-07-2024, 01:01 PM
  #6830
bd007's Avatar
Still learning the MMX shock settings. This is from what I have been reading. Correct me if I am wrong.
With arrangement I.
"Increase A-distance to increase damping and spring rates." Just like switching to stiffer springs in regular cars.
"Decrease B distance to increase spring rate at the fixed damping rate value." Just like standing up the shocks in regular cars.
hanulec likes this.
bd007 is offline
Old 05-07-2024, 01:35 PM
  #6831
https://www.youtube.com/watch?v=DH5mYcPr1IY&t=104s
glennhl is offline
Old 05-07-2024, 03:46 PM
  #6832
gigaplex's Avatar
With arrangement I.
A distance affects damping. Changing spring rate in a conventional car does not.
B distance does not affect damping. Changing shock angle in a conventional car does.
gigaplex is offline
Old 05-07-2024, 04:23 PM
  #6833
Pretty sure A distance affects damping and spring rate.
photeckk likes this.
glennhl is offline
Old 05-14-2024, 07:51 AM
  #6834
Team EAM
Trader Rating: 79 (100%+)
So whos building fresh kits for outdoor season?
EA
hanulec likes this.
EAMotorsports is offline
Old 05-14-2024, 10:13 AM
  #6835
Trader Rating: 20 (100%+)
Have one on the bench waiting to be finished.
EAMotorsports likes this.
hunterdawg is offline
Old 05-14-2024, 03:59 PM
  #6836
dawgmeat's Avatar
I have a carpet and an asphalt car probably gonna sell both
hunterdawg likes this.
dawgmeat is offline
Old 05-14-2024, 04:07 PM
  #6837
Team EAM
AMX USA will have fresh kits when you come back!
EA
dawgmeat, Nego and Ggrant like this.
Old 05-14-2024, 06:07 PM
  #6838
dawgmeat's Avatar
EA
HaHa
dawgmeat is offline
Old 05-20-2024, 04:45 PM
  #6839
bd007's Avatar
As I stated before, I am still learning my a800mmx. I think itís a good car at an excellent used car price point. However, I do curious how much better an a800R would be. I noticed the dampers are the major upgrades. Does it worth twice the price?
bd007 is offline
Old 05-20-2024, 09:32 PM
  #6840
What is .2 second per lap worth?
skyball likes this.
glennhl is offline
