Like Tree1257Likes
Awesomatix A800
    Hide Wikipost
Old 12-13-2018, 01:48 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800
Last edit by: IBxAnders
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 10-02-2015, 08:12 AM
  #31
Dan the Man's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Bar View Post
Shaft drive then!
If you're going by the thumb nail on the preorder page, it's the same one as the Evo II page
Dan the Man is offline
Old 10-02-2015, 08:17 AM
  #32
OVA
OVA's Avatar
Trader Rating: 82 (100%+)
Originally Posted by hanulec View Post
Okay I in...
OVA is offline
Old 10-02-2015, 08:21 AM
  #33
Bar
I did wonder that, as it's a CAD type drawing I assumed it was the new car
Bar is offline
Old 10-02-2015, 08:34 AM
  #34
OVA
OVA's Avatar
It is got to be different than current A700..just my .02
OVA is offline
Old 10-02-2015, 08:42 AM
  #35
DesertRat's Avatar
That's about $201 cheaper than I thought it would be.
DesertRat is offline
Old 10-02-2015, 08:53 AM
  #36
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Franko-- you are brand loyal. I promise.. You won't be disappointed!
hanulec is offline
Old 10-02-2015, 09:14 AM
  #37
gijoe64's Avatar
Trader Rating: 30 (100%+)
I want to see the chassis before I pre-order. but 599.99 is a great price
gijoe64 is offline
Old 10-02-2015, 09:50 AM
  #38
daleburr's Avatar
Yep, if you right-click the image and do a 'save as', it comes up with 'A700L-500x500.jpg'. So they're not revealing anything new just yet
daleburr is offline
Old 10-02-2015, 10:18 AM
  #39
R Dodge's Avatar
I've heard the 800 is driven by gold chains. This is from a very reputable source
Get ready for the bling
R Dodge is offline
Old 10-02-2015, 12:45 PM
  #40
OVA
OVA's Avatar
I cant wait
OVA is offline
Old 10-02-2015, 12:59 PM
  #41
Is there a forecast date, even an educated guess, on when this is coming out? The A700, as someone else said has never been big in the UK. The new price point would really help.
scoyle is offline
Old 10-02-2015, 01:06 PM
  #42
At least now with the new A800 we will have the opportunity to do a straight comparison between shaft(A700) and belt(A800) drives ...... Thanks Awesomatix......
bertrandsv87 is offline
Old 10-02-2015, 01:53 PM
  #43
That's in pretty bad taste to put a product up for preorder with a picture titled a800 underneath it and then when you save it it saves as a700.
2uzferunner03 is offline
Old 10-02-2015, 02:12 PM
  #44
R Dodge's Avatar
I'm curious what you think the thumbnail should be considering there has been no formal release of any information or photos of the A800. Once information and photos are made public, I'm sure the thumbnail will be corrected. Would you have preferred no thumbnail? Also, is it really that big of an issue?
R Dodge is offline
Old 10-02-2015, 02:21 PM
  #45
daveaustin5's Avatar
Yes, no thumbnail would be better. Or perhaps an Awesomatix logo.
Putting an image of the wrong car is only going to mislead people.
daveaustin5 is offline
