Awesomatix A800
#4352
There is not really any point to compare spring rates vs other cars.. generally the shock setup on an awesomatix feels very damped versus traditional shock cars, they feel like pogo sticks compared to an awesomatix. You just need to compare settings vs other awesomatix setups
#4353
Well, looks like I fail reading comprehension again! I have two Mid Motor A800's and on both I left the AT67 washer in place BETWEEN the two belts on the drive pulley. I was looking at the Mid Motor instructions tonight and just did notice that it says to move this washer to the far left of both belts. Why is this? Car seemed fine with the washer between the belts, but I went ahead and moved it to the far left on both cars. Why not just take the washer out?
#4354
Your better than me lol I didn’t read them and did the exact same thing . Been running them that way for a yr I’ll have to look at them again and see what difference it makes I would have thought it would have needed to be between the belts as well . But I did notice the new pully just released don’t even have the spacer
#4355
#4356
1. AM24-8 servo mount. AT67 on left side of pulley helps agains this.
2. Rear right long arm. AT67 on right side of center pulley helps against this. Note that the normal (not LA) rear arms don't have this issue.
I recommend to use AT67 on right side of our old center pulley for MM car with long rear arms.
New center pulley was designed to provide more gap between rear right arm and rear belt without AT67 using.
#4357
I got my first AMX car and I built this to the absolute T of the manual. Everything went together as expected. Im having an issue with my damper build for the rear. They went together smooth, i have the ride height screw backed all the way out and the lowest ride height I can get is 5.8mm Am I missing something? For the record they are built SRS1, 40wt oil and standard springs. I should also mention this is for a FWD car.
Thanks for any help you can offer.
#4358
#4360
By chance is this a VTA car. Sometimes those tall tires can cause problems of getting the car low enough. If not, I can't imagine what the problem is. What blocks are you running for the ride height screws, probably the P09X? Make sure the P09X block is seated all the way into the AM17XL/R damper holder. Also make sure your spring is pushed all the way down over the pin at the end. I'm betting the P09X plastic block is not seated all the way, you may have to trim it a little with an Xacto knife.
#4361
#4362
Also i woupd
like to note I used the po9 not the po9x you could remove the p09x outer holes if you don’t have any standard p09 parts . I also used the included standard springs with the type2 orientation
#4363
John,
Also, if I trim the P09X, do trim the top or bottom
#4365
i had the same issue with my fwd also when using the usgt style threaded tires . What I did was made the po9 thinner by .5mm also I shortened the short screw (Srs I think ) that .5mm allowed me to get rear down to 4mm .
Also i would
I love this site!! :-)
Thanks everyone!
John
