Like Tree938Likes
Awesomatix A800
    Hide Wikipost
Old 12-13-2018, 01:48 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800
Last edit by: IBxAnders
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 05-08-2019, 12:44 PM
  #4141
Originally Posted by Dan View Post
Helping a buddy rebuild his diff and shocks on an original A800 khaki color chassis car. It has the D2.1 dampers right?
Hoping the new upgraded O-rings will work on his older diff and dampers. Along with P45R and P46R.
Correct original A800 came with D2.1 dampeners.Pititrc has the A800 manual that also states D2.1.
malkiy is offline
Old 05-14-2019, 09:42 AM
  #4142
New PSS system is out
Al Sodano is offline
Old 05-14-2019, 10:59 AM
  #4143
Dan
Dan's Avatar
Trader Rating: 58 (100%+)
Picked up a used MMCX-A. I think it has the C27MM2 top deck. If I cut the center reinforcing ribs, does it make it exactly like the C27MMS-1? Or is the C27MMS-1 deck made of a softer, thinner carbon altogether?
Dan is offline
Old 05-14-2019, 12:09 PM
  #4144
geeunit1014's Avatar
Trader Rating: 14 (100%+)
If you make those cuts, they are extremely similar. The MMS-1 has just the st19, instead of the st55/st19, and the legs are slightly different but if you do not use the brace in the top deck (most setups do not) it is almost negligible.
geeunit1014 is offline
Old 05-14-2019, 12:18 PM
  #4145
Dan
Dan's Avatar
Good info, thanks! I will make the cuts and save $40.
Dan is offline
Old 05-15-2019, 03:10 AM
  #4146
i have tested both and prefer the non S version cutting it manually the car responses much faster compared to the s version which is a lot easier . Look at the kink on the lower right it is a lot thicker on the non s version.
BD1541 is offline
Old 05-17-2019, 10:36 AM
  #4147
Kodey65's Avatar
Cant wait to try new PSS! Thank You RC Maker for providing informative video!
Kodey65 is offline
Old 05-19-2019, 09:18 AM
  #4148
R/C Tech Elite Member
What is the size of bearing for the AM74 belcrank?
thanks
Psychotikcow is offline
Old 05-20-2019, 06:42 AM
  #4149
thanks
8x5x2,5mm
Oleg Babich is online now
Old 05-22-2019, 08:33 AM
  #4150
Trader Rating: 50 (100%+)
Anyone if the Awesomatix servo will be fine with 7.4volt bec?
v_squared is offline
Old 05-22-2019, 07:59 PM
  #4151
nexxus's Avatar
Trader Rating: 313 (100%+)
Never tried it but I have been told no (could be wrong)
nexxus is offline
Old 05-23-2019, 09:01 AM
  #4152
Have 2 MM 800x's I am looking to move if anyone is looking
robbie_gtc is offline
Old 05-23-2019, 08:31 PM
  #4153
i dont have your answer but maybe a clue. i run the servo on hvlipo 8.65 volts and a sanwa super vortex gen 2. if the s-gen 2 is not regulating and i donít think it is then you have your answer.
Bry195 is offline
Old 05-24-2019, 04:53 AM
  #4154
Are you sure the Super Vortex gen 2 is not regulated and output battery voltage for bec?
Old 05-24-2019, 08:17 PM
  #4155
no. i only suspect because the servo slows as the voltage drops. but you can look at the manual and it will tell you.
Bry195 is offline
