Like Tree784Likes
Awesomatix A800
    Hide Wikipost
Old 12-13-2018, 01:48 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800
Last edit by: IBxAnders
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 03-29-2019, 08:19 PM
  #4036
I only found 1 USGT carpet setup on Petit. Does anyone have some guidance or a setup for asphalt?
Bry195 is offline
Old 03-30-2019, 10:08 AM
  #4037
Hi everyone,
Do you know where to find the Mid conversion kit in stock in the US?
Thanks,
jandrestbb is offline
Old 03-30-2019, 11:35 AM
  #4038
colcan's Avatar
Are u looking for carbon lower deck or aluminium?
colcan is offline
Old 03-30-2019, 11:41 AM
  #4039
colcan's Avatar
Ryan Maker has in stock mid-conversion. Check it out on rcmaker
colcan is offline
Old 03-30-2019, 07:21 PM
  #4040
DBM
Looks like he is out of stock of the aluminum mmcx conversion kit.
DBM is offline
Old 03-31-2019, 05:20 AM
  #4041
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by jandrestbb View Post
Hi everyone,
Thanks,
Even the manufacturer was out of stock
I'd recommend you back order at Awesomatix USA. This way you'll get it when they do arrive.
hanulec is offline
Old 03-31-2019, 09:41 PM
  #4042
Going from a short arm setup to a long arm is there any way to get comparable rollcenters right now with front +1.5 I have standard balls on the chassis and 3mil up top with 1.75 on the hub . Going the the +9 what would be comparable or just leave it
nexxus likes this.
john holmes 69 is offline
Old 04-01-2019, 04:57 AM
  #4043
hanulec's Avatar
No science yet... Maybe Oleg has some.
LA cars seem to like higher roll centers (0.5 to 1mm) more than std or even 1.5 arms
hanulec is offline
Old 04-01-2019, 06:19 AM
  #4044
Calculations showed that our long arms need ~0,5mm less shims under lower inner AT21 balls to get the same roll center as it was with +1,5 arms. But our initial test of long arms on track showed that the car was better without this correction of the lower balls.
So it seems that our long arms are better at a bit higher roll centers than it was with normal arms.
Oleg Babich is offline
Old 04-01-2019, 11:55 AM
  #4045
I've been waiting to drive my Evo MMCX all winter, as I prefer asphalt. First time driving the car after switching from AE. This car feels so good. Any apprehension I had about going MM despite never running the standard layout, is gone. Took TQ, but unfortunately didn't finish A main due to the setscrew falling out of the pinon. Someone told me I need to shave the chassis to motor slightly to make sure the motor is flush? I have a feeling it was simply bad luck.
Kodey65 likes this.
TurboDrifter is offline
Old 04-02-2019, 12:18 PM
  #4046
Tremor24's Avatar
Hello, how many race days are people going between changing shock seals with the new high durability seals? Since the seals are sold in single packs it seems that they are not intended to be replaced super often but Iím curious as to otherís opinions.
Tremor24 is offline
Old 04-03-2019, 05:47 AM
  #4047
Trader Rating: 19 (100%+)
Depends on your motor and how you have it mounted. With a MC2 I either had to shim the motor out or clock it so the bottom endbell screw wouldn't hit the chassis cutout. You could grind the cutout longer for clearance if you wanted.
Motors like the Can-Am Stock motor have a flush endbell so it's not an issue...
iTz Nicholas72 is offline
Old 04-03-2019, 06:42 AM
  #4048
Trader Rating: 50 (100%+)
Grind the screw head at a 45 degree angle and problem solved on the MC2. Or do what we do just take that screw out. Never had a problem ever doing it that way...
Kodey65 likes this.
tonyd is offline
Old 04-03-2019, 07:25 AM
  #4049
hanulec's Avatar
People buy these like crazy.... But I don't see why
My orings stay in the car until the car is sold or oring is dropped on the floor
Tremor24, tonyd and iTz Nicholas72 like this.
hanulec is offline
Old 04-03-2019, 09:30 AM
  #4050
i've ran my car for almost 3 months now with club racing every friday, plus practice and 3 major races, they are still intact and not leaking. I think the new rubber is definitely doing a better job at holding oil in the shocks. I would say change them when you see one shock starting to leak.
Tremor24 likes this.
martiniracing is offline
