Like Tree785Likes
Awesomatix A800
    Hide Wikipost
Old 12-13-2018, 01:48 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800
Last edit by: IBxAnders
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 03-19-2019, 02:50 PM
  #4006
Tremor24's Avatar
When running the springs bent for a more linear action (98, 110 etc) are people polishing or lubing the contact locations between the spring eyelet and the spr02x? The metals sliding aren’t smooth and seem to “skip”.
Tremor24 is offline
Old 03-19-2019, 03:30 PM
  #4007
tbrymer's Avatar
Hmm. Never thought about putting some lube on that, but some good copper based anti-cease lubricant (like they use in guns)
Kodey65 likes this.
tbrymer is offline
Old 03-20-2019, 05:34 AM
  #4008
Trader Rating: 19 (100%+)
iTz Nicholas72 is offline
Old 03-20-2019, 05:52 AM
  #4009
Originally Posted by iTz Nicholas72 View Post
Is this SMC motor in the lowest possible position?
Oleg Babich is offline
Old 03-20-2019, 06:05 AM
  #4010
It's not. You need to have the tabs on top to run it lowered. Tried clocking the endbell but that didn't work.
Old 03-20-2019, 06:21 AM
  #4011
Sam Isaacs's Avatar
Trader Rating: 25 (100%+)
Nice wiring. A lot of people have been going to the SMC motors in mod tc (some are really liking the 6.5T Low Rider as well, so that could be something to try).
Sam Isaacs is offline
Old 03-20-2019, 07:56 AM
  #4012
John Doucakis's Avatar
Very nice work Nicholas. Bravo
iTz Nicholas72 likes this.
John Doucakis is offline
Old 03-20-2019, 10:21 AM
  #4013
syndr0me's Avatar
Trader Rating: 32 (100%+)
Can confirm. Love this motor for mod sedan with the 12.0 rotor.
syndr0me is offline
Old 03-20-2019, 12:35 PM
  #4014
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Wink
Nick if you start spending some time on your car you'll probably get that birds nest cleaned up...
RKeasler is offline
Old 03-20-2019, 01:19 PM
  #4015
I have an A800X with soft alloy chassis. For running outdoor/asphalt, what should I get?
- Carbon chassis, which version?
- long arms?
- anything else?
where can i find good starting setup for very low traction asphalt?
micsa is offline
Old 03-21-2019, 09:44 AM
  #4016
Kodey65's Avatar
- long arms?
- anything else?
Lots of folks are going to Mid Motor Carbon
Yes get the long arm set
Do a google search for PetitRC Awesomatix - There is a wealth of information on 800x and setups for asphalt and carpet.
Kodey65 is offline
Old 03-21-2019, 10:45 AM
  #4017
Super Moderator
Marcos.J's Avatar
Trader Rating: 205 (100%+)
- long arms?
- anything else?
Awesomatix A800 & A800X Setup Sheets
Ggrant likes this.
Marcos.J is offline
Old 03-21-2019, 02:47 PM
  #4018
Originally Posted by Marcos.J View Post
hey come on Marcos , don't let anyone know about our little secrets lol lol
Marcos.J likes this.
Ggrant is offline
Old 03-23-2019, 02:07 PM
  #4019
whats a good place to purchase a new a800 with the latest upgrades?
jessele is offline
Old 03-23-2019, 04:05 PM
  #4020
tbrymer's Avatar
awesomatix usa, rcmaker, michael's hobbies
Tremor24 likes this.
tbrymer is offline
