Like Tree785Likes
Awesomatix A800
    Hide Wikipost
Old 12-13-2018, 01:48 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800
Last edit by: IBxAnders
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 02-09-2019, 01:21 AM
  #3856
foampervert's Avatar
Default Mmcx vs vtd
Hiya folks,
I have a a800x Evo which I run vtd with. The car is super fun to drive, but am wondering how it compares with the mmcx. I drive on a mid traction outdoor asphalt track.
I use the stock carbon chassis currently. I find that it has a bit more steering compared to the stock topdeck, but definitely not as much as I like.
foampervert is offline
Old 02-09-2019, 07:20 AM
  #3857
Team EAM
Trader Rating: 79 (100%+)
Originally Posted by trilerian View Post
When does Awesomatixusa get shipments in?
Usually about every 10 days or so but it depends on AMX production schedule and availability as well.
EA
EAMotorsports is offline
Old 02-09-2019, 08:08 AM
  #3858
geeunit1014's Avatar
Originally Posted by Jamison R View Post
Can you post Gee's MM set up? I cant find it. Thanks
i think he means running my rear motor setup on the mm car. Iíve never published a mid motor setup, I prefer the rear motor car
Ggrant likes this.
geeunit1014 is offline
Old 02-09-2019, 08:20 AM
  #3859
Trader Rating: 35 (100%+)
Does the MMCX kit work on A800A version?
joech is offline
Old 02-09-2019, 08:21 AM
  #3860
Super Moderator
Marcos.J's Avatar
Trader Rating: 205 (100%+)
yes you just need to change the swaybar mounts P12X, at142 and b63SS
Ggrant likes this.
Marcos.J is offline
Old 02-09-2019, 09:58 AM
  #3861
mac853's Avatar
Could someone tell if makes big difference in case use middle motor conversion kit?
In fact i saw Machler in IIC only use MMCX to run in 17.5 class but Spec GT just run normal version car.
mac853 is offline
Old 02-09-2019, 11:53 PM
  #3862
Want are the advantages to running shorty pack battery with the new weighted adapters?
LAGuy is offline
Old 02-10-2019, 12:26 AM
  #3863
Maybe we can hear it from Oleg since i noticed x ray seems to be doing the same now.
BD1541 is offline
Old 02-10-2019, 01:20 AM
  #3864
More weight down low would be my guess. Lower CG would make a faster more nimble car.
LAGuy likes this.
RickyBobbyRC is offline
Old 02-10-2019, 06:05 AM
  #3865
tbrymer's Avatar
Faster corner speed on high traction.
LAGuy likes this.
tbrymer is offline
Old 02-10-2019, 06:36 AM
  #3866
Originally Posted by Adam W. View Post
The dot is going to vary on the tension and age of your belt. I think I have mine about one dot forward on the bottom. Make sure they are the same on both sides though. Check your steering degrees. I have mine set at 25 degrees. I had them set at about 32 degrees and was over-steering the car which caused a lack of front traction. When I pulled it back to 25 degrees it made a big difference.
Sorry for the dumb question, I am new to AMX. can you explain the steering degree. Do you mean in the radio, or is this something I can adjust on the car?
I will try the belt setup. I have mine set on the top, not sure what this affects.
ryan391 is offline
Old 02-10-2019, 06:39 AM
  #3867
I dremeled out the steering arms also. This is my setup sheet for our black CRC carpet track. The car is dialed in with this setup on my 800x. see the attachment.
Thank you for the set! I set up almost exactly per you sheet. Worked very well. Car was a lot more in control. Still loose in the back end, but I need to add some weights. I only have the stick on kind. I would need a bunch of these to get to the weight I want.
ryan391 is offline
Old 02-10-2019, 01:49 PM
  #3868
Does anyone have P03 in stock???
Is there a way to remove P03 without damaging it?
I ordered a A21S ballstuds, but don't have enough spare P03 cups to put on all the new studs. Nobody seems to have them in stock. So I either need to re-use some P03 cups, or wait to install A21S until I can get them.
edit: Found P03's at Michaels Hobby in Florida. Still curious if there is anyway to remove them without damaging.
JeffC is offline
Old 02-10-2019, 02:50 PM
  #3869
I ordered from RCMaker in Australia, It has been a week and for some reason it is going through Germany.
I may never see them
ryan391 is offline
Old 02-10-2019, 04:43 PM
  #3870
you will get them, RcMaker is reputable, it might just take some time depending on the shipping type you chose, considering itís coming from Australia.
martin Paradis
rhodopsine is offline
