Like Tree785Likes
Awesomatix A800
    Hide Wikipost
Old 12-13-2018, 01:48 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Awesomatix A800
Last edit by: IBxAnders
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 08-17-2018, 06:03 PM
  #3256
Super Moderator
Marcos.J's Avatar
Trader Rating: 205 (100%+)
Originally Posted by bertrandsv87 View Post
Nice......Battery wires could have been much shorter by turning the battery around the other way...Good luck...
the + and - side is the lighter side of the battery
Marcos.J is offline
Old 08-17-2018, 06:48 PM
  #3257
That's the side you want facing the rear of the car to move the weight forward. That would have saved a good 20 grams of wires high on top of the battery that can be moved down to chassis level to lower the CG...That's about 0.2sec per lap right there on top of the other 0.4sec per lap he could have gained by running a 2.5t , 3.5t or brushed Fantom motor.....lol...
bertrandsv87 is online now
Old 08-17-2018, 06:54 PM
  #3258
gigaplex's Avatar
I don't know if you've noticed, but the motor is quite a bit further forward than normal. And that length of wire is not an additional 20g, more like 5g.
Marcos.J likes this.
gigaplex is offline
Old 08-17-2018, 10:18 PM
  #3259
I really doubt that two 137mm long pieces of 12gauge wire only weigh 5grams....
Old 08-17-2018, 11:45 PM
  #3260
OVA
OVA's Avatar
Trader Rating: 80 (100%+)
it is pass your bed time Bert...
OVA is offline
Old 08-18-2018, 05:53 AM
  #3261
Originally Posted by hanulec View Post
I suspect more people will want MMCX conversions Oleg
Round 1 went amazingly well!
On the way.
iTz Nicholas72 and skyball like this.
Oleg Babich is offline
Old 08-19-2018, 11:47 PM
  #3262
Originally Posted by Oleg Babich View Post
On the way.
Oleg,are there Plans to make complete MMCX Mid Motor Car Kit?
So,a complete Car?
I ask beacause i would like to buy a second car next to our A800X.
tbrymer likes this.
MKAH is offline
Old 08-21-2018, 01:48 PM
  #3263
I recently got two A800X cars for asphalt 17.5 and 21.5. I need help on understanding the effect of different settings other than the standard camber, caster, toe, height, droop, damper and spring rate. There are a bunch of shim settings on the setup sheets that I need to understand it’s effect. Can someone help with a brief explanation or point me in the right direction. I’m currently copying the settings from someone else but it doesn’t really help since We all drive differently.
ears4fear is offline
Old 08-21-2018, 01:59 PM
  #3264
Super Moderator
Marcos.J's Avatar
Originally Posted by ears4fear View Post
I recently got two A800X cars for asphalt 17.5 and 21.5. I need help on understanding the effect of different settings other than the standard camber, caster, toe, height, droop, damper and spring rate. There are a bunch of shim settings on the setup sheets that I need to understand itís effect. Can someone help with a brief explanation or point me in the right direction. Iím currently copying the settings from someone else but it doesnít really help since We all drive differently.
look here there is a ton of information under "tips and tricks"
Awesomatix A800 & A800X Setup Sheets
Marcos.J is offline
Old 08-22-2018, 05:22 AM
  #3265
Trader Rating: 19 (100%+)
My year and a half old XA chassis is slightly tweaked. Was going to get an XAH because I just run 17.5TC on black carpet. Debating getting the XA-LA now...
iTz Nicholas72 is offline
Old 08-22-2018, 07:03 AM
  #3266
Hi guys, where did this picture of new upcoming parts come from ?
I don't really know where to find the officiel information (news) about the car, the website is almost dead since 5 years, awesomatix usa look like a shop / forum but do not publish all the news...
any idea ?
antho2b is offline
Old 08-22-2018, 07:04 AM
  #3267
by the way, any idea where I can find a mid motor upgrade kit ?
antho2b is offline
Old 08-22-2018, 07:24 AM
  #3268
geeunit1014's Avatar
any idea ?
Most news is coming from the Awesomatix Facebook page now
geeunit1014 is offline
Old 08-22-2018, 01:23 PM
  #3269
dawgmeat's Avatar
Any plans to update the setup sheets with all these new changes
dawgmeat is offline
Old 08-22-2018, 01:26 PM
  #3270
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 27 (100%+)
a second edition of the MMCX has just been released. distributors have ordered... and should be getting them in the next week
iTz Nicholas72 likes this.
hanulec is offline
