Awesomatix A800/A800R
#2821
Must Have Parts:
Parts you should have for the first exit with your A800 / A800A / A800AH.
Option Parts recommending our team drivers.
1x SPR01S Soft springs
2x C04AL + 0,5 Longer rocker arm / lower crossbar for the front axle
1x MMP 001 Awesomatix Follow-up measuring pointer for various setup systems
1x A64SG-100 main gear wheel for cane (100 teeth 64dp)
1x A64SG-116 Master gear for Modified (116 teeth 64dp)
Here is an overview of the parts you should have in the bag for the case.
2x B106RS ball bearing
1x P01 ball socket
1x P02 ball socket
1x P03 ball caps
1x P04 Wheel support bracket
1x P05 stabilizer clips
1x P06-1 Outfeed travel sleeve
1x P07 swinging clips
2x P13-4 ball pans
1x P16 Holder for the Kardans
1x P46 foam seal for GD2B
1x ST16 cardan parts
1x AT14 threaded rod
1x BEL189B Rear strap
1x BEK513B Front strap
#2822
Jake
#2823
Running on a small technical medium grip Grey CRC track with Sorex 32s or 28s should I start with the stock setup or find something on PetitRC?
#2824
Pss new system how to modify damper holders
Hello can awesomatix support show us how to modify our damper holders to use pss system an the measurements on the setup sheets. To understand the position 4.4 4.6 where are you measuring to get these numbers. Greatly appreciated
#2825
Hi everyone,
Here is my setup from the Tonisport Onroad Masters held at the Arena33.
I didn’t have an aluminium chassis, therefore, the car was initially way too aggressive and hard to drive.
To combat the excess grip and rotation I ran the car with anti-dive in the front and a thicker front swaybar.
This made the balance of the car much better and thus made the car easier to drive while still rotating pretty good.
I would recommend trying the anti-dive and a 1.2 swaybar to anyone who is planning on running the carbon chassis on high grip carpet.
Feel free to ask if you have any questions.
Kind Regards,
Mitchell
Kind Regards,
Mitchell
#2827
R/C Tech Elite Member
Awesomatix USA MAKES the Caster Doodle. This is our 4 year old product first debuted at the 2013 Vegas/IIC Race. It has a ton of IIC, ROAR Nationals and other wins behind it. Its probably good enough...
Caster Doodle
there is also the Radtec Caster Doodle
Awesomatix Caster Setup Tools
#2828
My XA will be here today. Read all the guides and watched all of the RC Maker videos so hopefully it goes smoothly.
Going to start with the stock setup. Though should I go ahead and install the soft springs for medium grip Grey carpet is try the hard first?
#2831
I'll start with the S springs then.
Traction has been on the higher side lately even some traction rolling on Jaco Blues.
Do I set the damper gaps the same with the S spring?
#2832
Results with the A800 has been exceptional for me this year - such that a few fellow racers have now moved towards investing into this kit once they drove mine.
#2834
Most run the SRS 1 arrangement where the ride height screw is closest to the damper. A decent ballpark spot to start for the soft springs is around 75 gF/mm front, and 85 gF/mm rear. Front and rear damper gap ballpark around 2.6 - 3.0 mm. This should be decent at Bush River.
#2835
Or152s
Hello i have at78 and or152 o-rings.. I see on awesomatix site That you now can get new o-rings (OR152S) i Wonder if anyone got at78 and having trouble with or152? Wonder why the new o-ring?
