Like Tree472Likes
Awesomatix A800
    Hide Wikipost
Old 01-12-2017, 07:43 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Awesomatix A800
Last edit by: Sam Isaacs
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Old 10-22-2015, 12:55 PM
  #166
WesRaven's Avatar
Originally Posted by mbykerman View Post
Where do you order from?
Since it looks like you're outside of the US, you can pre-order the car on the official site here.
US customers can get it here.
WesRaven is offline
Old 10-22-2015, 01:11 PM
  #167
Originally Posted by patorz31 View Post
I think it is to just broaden Awesomatix market share by giving the belt drive guys (like Me) a awesomatix to buy.
It's not just to broaden the market, initial testing showed the car is easier to drive and provides more overall traction. Also the car has much less parts, which makes it more affordable while keeping the high quality and the other nice features.
A lot of parts from the old car can also be used in the new one, all suspension parts, diff internals,...
Kind regards
Marcel
Marcel is offline
Old 10-22-2015, 01:33 PM
  #168
WesRaven's Avatar
Was there any testing done on drag efficiency between the belt and shaft? Just curious what kind of impact this car will have for the limited horsepower spec classes (17.5 and higher).
WesRaven is offline
Old 10-22-2015, 02:20 PM
  #169
huge8's Avatar
Angry
sadly but Im greenhorn to share link this forum
anyway it's out now with single belt drive
huge8 is offline
  #170
The car is running very "free", in 13.5t blinky we set a new track record on my hometrack....i don't think you will notice a difference in drag.
The car still has a super good corner speed, just because of the very low cg.
kind regards
Marcel
Marcel is offline
Old 10-22-2015, 02:27 PM
  #171
huge8's Avatar
"Specifications:
– Suspension system with rotary dampers, A-type lower arms and top links
– Very centralised motor and battery position
– Centralised belt position for reduced chassis twisting
– Spur gear changes within seconds
– Extra lightweight front spool, gear diff and alloy centre pulley
– One piece motor mount attached exactly on the centre line of the chassis
– Motor mount integrates chassis flex tuning options to handle various grip levels
– Chassis designed with symmetrical cutouts and recessed areas for symmetrical flex
– Choice of alloy or carbon chassis
– Alloy central chassis stiffener for multi-step flex tuning option and increased longitudinal stiffness
– Top deck offers a “floating” option for extended flex tuning
– “Keyed” bulkheads and motor mount for precise arrangement on the chassis
– Additional 10 g and 5 g weights with flex affecting option"
huge8 is offline
Old 10-22-2015, 02:57 PM
  #172
patorz31's Avatar
Oleg is this a Twin Belt or Single Belt design?
patorz31 is online now
Old 10-22-2015, 02:58 PM
  #173
Twin Belt.
Oleg Babich is offline
Old 10-22-2015, 03:02 PM
  #174
patorz31's Avatar
That's what I thought from this pic.
Old 10-22-2015, 03:03 PM
  #175
patorz31's Avatar
Nice car Oleg, you'll have a new customer soon.
Old 10-22-2015, 03:08 PM
  #176
Schwarta's Avatar
Looks like the arms will just about bolt straight over. The shocks may have to fix to the chassis differently, wouldn't think you could use am08-1 over the belt.
Are the arms the same part number? I wonder why the alloy over carbon? Sounds like they use the new am06s-m hubs.
Edit-
Kind regards
Marcel
What gives it more grip? The motor layout?
Schwarta is offline
Old 10-22-2015, 03:17 PM
  #177
How do you adjust the belt tension and is there going to be a front gear diff available when the kits start shipping?
Patrick
XCELL is offline
Old 10-22-2015, 04:32 PM
  #178
daktulos's Avatar
So Oleg for the aluminum chassis to clear the motor you made a recess the lenght of the battery on both side and for the carbon just a slot on both side?
How thick is both chassis?
What is the decision to change the steering rack to a dual bell crank vs the system on the A700?
Thanks!
daktulos is offline
Old 10-22-2015, 04:40 PM
  #179
Trader Rating: 29 (100%+)
Great looking for sure and very tempting. Nicely done
branover is offline
Old 10-22-2015, 05:08 PM
  #180
Dan
Dan's Avatar
Trader Rating: 53 (100%+)
Looks cool! I'm a spec racer mainly so I'll stick with my shaft drive A700. Glad to see this car will grow the brand more and always good to see something different.
Dan is offline
