Old 11-03-2005, 06:55 PM   #1
Post Team Orion goes Li-poly.
http://forums.radiocontrolzone.com/s...d.php?t=208344
Mabuchi540 is offline   Reply With Quote
Old 11-03-2005, 07:02 PM   #2
ChadCapece's Avatar
I hope we don't have to get new TC's to run the lipo's, since they weigh less than a Nimh battery.
ChadCapece is offline   Reply With Quote
Old 11-03-2005, 07:06 PM   #3
Sushi Man's Avatar
Send a message via AIM to Sushi Man
YEah but a lot of Li Pos have high IR, i dont know about these, i tied making my own 7.4 pack and it was slow/....
Sushi Man is offline   Reply With Quote
Old 11-03-2005, 07:19 PM   #4
Mike Haynes's Avatar
I have used the scorpion 3.2ah cell balencer setup, and it is VERY nice, way more punch then ruglar cells, and the light weigh was nice, i have a losi so the car was still balenced, just a little looser then normal.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 11-03-2005, 07:29 PM   #5
geeunit1014's Avatar
it was only a matter of time...
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 11-03-2005, 07:33 PM   #6
Hick's Avatar
Been running LiPo's for almost a year now. Use Ice Machine to charge, no problem, just follow instruction on how to set the "charge program" up. If anything goes wrong with the charging process, including battery temp. Everything shuts down.
I can charge them today and run them next week w/o repeaking with plenty of power. Repeaking only gets you about 200 more mah's. Charge time is slow.
No problems with power, I have only compared them with 3300's and voltages were the same at 1/2 minute markers. Run time is approximately 15 minutes under a 30 amp load. Run them with 10x2 motors; last laps as fast as first laps. Have a goofy little LED Lite that must be visable on the car that when it goes out. Quit running the car. Don't use lite because I run them for a few hot laps, a 4 minute heat race and recharge. No discharging necessary.
The loss of 6 ozs in my B3, CW Sprinter and Intimadator (sp) was very welcome, just a few turns of the shock adjusters. Of course, later less wt shock oil, softer springs. Cars just got better. Tried them in a pan car, well lets say I tried them in a pan car. Car slide ways - all over the place, and I didn't feel like messing with it. Haven't tried in TC3 yet, don't expect much of a problem.
Only problem I have experienced with LiPo's is recharging them. When the ambient temperature is above 95 degrees (battery temp cut off) the battery must be put in the refrig for awhile.
Overall very pleased with the batteries. I didn't have to pay no $125.00 for them either.
Hick is offline   Reply With Quote
Old 11-03-2005, 07:56 PM   #7
AdrianM's Avatar
Actually all modern LiPo packs have extremely low IR's. I don't know what you used but if it was made from recent 10C+ and it had the current capacity to handle the motor you were running it should have been ballistic.
Adrian Martinez
Old 11-03-2005, 08:33 PM   #8
great 200.00 battery packs.
gotyournumber is offline   Reply With Quote
Old 11-03-2005, 08:41 PM   #9
T. Thomas's Avatar
I have a friend who flies planes, his only complaint about lipos is how they are affected by cold weather. Is there any relationship between weather and these cells? Too hot a climate, they wont charge, too cold they don't hold a charge????????????????
T. Thomas is offline   Reply With Quote
Old 11-03-2005, 08:47 PM   #10
josh69162's Avatar
Send a message via AIM to josh69162
Chemical reactions take place slower in colder temperatures. That's why if you cook your battery pack up to 200 degrees, it will be stupid fast (for one run ). I don't know about it being too hot... I haven't heard that one.
-Josh
josh69162 is offline   Reply With Quote
Old 11-03-2005, 08:53 PM   #11
BlackKat's Avatar
Hundred and twenty five bucks a pack? Bring on the innovation :\
This is seriously going to change R/C the way we know it. For some of us, in a good way...for the budget runners its gonna suck.
BlackKat is offline   Reply With Quote
Old 11-03-2005, 09:32 PM   #12
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Hopefully the Novak GTB will work with it. Might take the plunge to lipos once these babies are out.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 11-03-2005, 09:46 PM   #13
Hick's Avatar
As the newness wears off they will get cheaper... point proven many times with other R/C products.
In the cold, you can put them under your arm, sit on 'em like a chicken hatching and egg, but, I prefer a heating pad set on low. When coming off the track after a 4 minute run the batteries are only slightly warm, about body temp.
In my experience, once the secrets of LiPo's are learned they well be more economical.
The rumors we have all heard about LiPo are true. But the have to be abused, running below cutt off, blowing up when they are severely over loaded and they don't like water.
Old 11-03-2005, 10:13 PM   #14
Ghostfit's Avatar
Thats strange, I've heard that if you ever accidentally punctured one, the best thing to do is to dunk them into a pail of water, better still if it is salt water ! something about neutralising the chemicals.
Ghostfit is offline   Reply With Quote
Old 11-03-2005, 10:29 PM   #15
BlackKat's Avatar
Do LiPos "fall-off" like the NiMh cells do? Is there going to be any way to "grade" these cells or will full LiPo in R/C put the matchers out of buisiness?
FS: Team Losi Li-Poly Receiver Battery Pack (7.4V/2000mAh) XT8Truggy Australia For Sale/Trade 0 08-14-2008 05:40 PM
Team Orion Platinum Edition 4800mAh Li-Poly Battery Atom357 R/C Items: For Sale/Trade 3 07-08-2008 05:22 PM
Team Orion Platinum Edition 4800mAh Li-Poly Battery Atom357 R/C Items: Wanted to Buy 1 06-26-2008 05:19 PM
Orion Advantage DC Computerized Charging System (NiCD, NiMH and Li-Poly) DaSilva R/C Items: For Sale/Trade 23 01-29-2008 08:02 PM
Kyosho 1/8 Suzuki Motorcycle With Team Orion Coreless Motor And Team Orion Flash Esc hpidriver R/C Items: For Sale/Trade 3 07-04-2003 07:56 PM
