New IRIS by AME
#287
If you do a little more or less Shimms on one than on the other, you change the caster.
Doing the same amount of Shimms on both will change your camber.
Its a litle bit Like Awesomatix only without Turnbuckles.
Correct?
So correct?
#289
Power delivery to the rear seems to be via 1 belt, while power to the front will have to go via 2 belts (and a very loose center belt). Still possible to have the front pull the car on power instead of the rear pushing the car (i.e. belt tension to front tighter than rear)? Thanks.
#290
I've never bought into a tighter front belt making the front pull more than the rear pushes. Both belts drive the same, doesn't matter on the tension (unless it's so loose that it starts to skip or so tight that it binds up the bearings). I've always considered it to be just another urban legend of RC racing. And don't get me started on chassis flex being your friend!
#291
Regional Moderator
#292
Wow......What a design !!!
#293
you guys know there are papers on this topic right?
belt tension vs efficiency isn't voodoo magic
#294
#297
Why would it bind? It's three ball joints, should be fine.
EDIT: Actually I am wrong and Lonestar is correct. Slight binding from the two ball joints being at an angle creating a longer distance between the balls. But probably very slight like he said.
#300
After looking at the manual and the pictures from the ETS, I'm still trying to decipher what the purpose of the M2.5 screw in the middle of the bulkhead is for? It looks like 3 screws per bulkhead to attach them to the chassis (but why 3?) and then 3 grubscrews per insert/hingepin (2 to hold the insert, 1 to lock the pin)?
