New IRIS by AME
#271
its like anything else on the internet, without actually driving one, touching one or seeing one everyone has a opinion ,
#272
Seems like the worst of both worlds. Lowering belt tension decreases friction but increases the chances of belt skipping. This 3 belt setup will still have more friction even with the loose belts, and still have increased chances of belt skips. Plus the orientation of the belt pushes the motor further away from centreline which is not ideal.
#273
Right now all we have are the pictures. So questions are as natural as dirt. And just as messy!
I admire the tech. Always.
#275
And congratulations to Andreas Myrberg
There is some bold, clever stuff going on in the Iris.
#276
ah, so they did go the route of shimming the upper bulkhead for RCH adjustment.
#280
Not a stupid question at all, I just searched heave suspension on Youtube. Seems to have some pretty good vids on it.
#282
Pretty disappointing to see the adjustment for camber/caster relies on shims. pretty much eliminates any quick adjustments and require the 2 ball stud to be completely backed out, guess the thickness of shim needed, reassemble everything, put the car back on the setup station, just do repeat everything again if its not enough. Also with all these loosening and tightening of the ball stud into plastic arm, its just a matter of time before you strip those threads.
I have a feeling a lot of people will just adapt the Awesomatix style double turnbuckle upper arm instead.
#283
With all the fullscale prototype / openwheel inspired design on this car, I'm surprised they didn't rip a page out of that book either.
#284
someone will come up with shims that's basically the shape of the rcmaker arm clips for the AX and problem solved. Just back it out enough to add and remove the shim, retighten and boom, camber change done.
Well, it would work that way, if they included some setup table in the manual... The whole manual feels a but messy, without explanation how can you change the setup.
#285
Can someone explain to me how to set the caster.
I don't see anything there that I know from the MTC 2, for example.
