New IRIS by AME
#242
Can roll centers (suspension arm height) be adjusted?
#244
This design has the spur closer to the centerline compared to the newer 2-belt designs. From pictures alone (may be wrong), it seems that both the servo and the motor are at least 1-2mm more outwards in comparision to a800, mtc2, x4, etc.
#246
the plastic pieces is to "key" the torsion bar into the damper piston, and the chassis attachment on the last picture of post 229, has zero to do with roll centres.
#247
Seems like the worst of both worlds. Lowering belt tension decreases friction but increases the chances of belt skipping. This 3 belt setup will still have more friction even with the loose belts, and still have increased chances of belt skips. Plus the orientation of the belt pushes the motor further away from centreline which is not ideal.
Bigger pulley for 3rd belt gives more contact on the belt. Increased teeth engagement less chance to skip with a looser tension.
Spool and Diff belts inline with chassis center means less torsional flex effect to belt alignment. Allows for less belt tension to prevent skipping.
Only Con is the power loss in the extra rotating parts. Dont know how to explain that in 'engineering' terms. Something to do with the energy needed to spin them minus the usable energy output of the driving component (aka motor).
Kind of why a shaft drive car can plant more power to the drive train compared to belts.
Battery and motor farther away form center though could help with weight transfer.
As long as they dont overhang and make contact with the race surface then you can tune for the weight shift.
I think theres a lot of benefits in the logic behind the cars design. Possibly too many people focused on whats considered the 'normal' these days for cars.
Many questioned AMX when they came with their ideas, but now we know they work.
#248
take a look at stadler's 3rd belt "tension" lol
#249
My theory thinks of it this way ....
There's no benefit to having the battery/motor mass hanging further out. That increases the polar moment of inertia, slowing down rotation.
There's some potential benefit with the suspension design, but the drivetrain doesn't appear to have any benefits. It'll be heavier and have more frictional losses.
#250
2 big additional pulleys may add a gyroscope effect that would resist rotation.
Wouldn't shorter (less belt wrap) front and rear belts make it more susceptible to slippage vs a longer belt?
#252
The engineering term is called friction.
#253
I am also interested in seeing how the roll centers can be adjusted. Very interesting car that I think will work well in mod.
#255
Hopefully the manual gets uploaded soon. I'm quite curious to see how the lower arms attach, how long they are front inner to outer pivot and how easy/difficult it will be to make roll center adjustments.
