New IRIS by AME
#169
Hopefully IRIS can make a 3 pulley and the true mid motor position work. Other manufacturers could not. Interesting would be the suspension and the overall cg.
#170
#172
It's already easy to get a perfect 50:50 weight distribution with the equal length belt layouts. The motor isn't the only heavy component in the car.
The "true" definition of a mid motor layout is that the motor is somewhere between the front and rear axles. I'm not sure why the RC crowd think it needs to be exactly half way between the axles.
#174
My existing mid car is already slightly front heavy with the motor behind the spur and equal length belts. Moving the motor further forward will exacerbate this, requiring more weight added to the rear to maintain 50:50. That'll actually make the polar moment of inertia higher.
#175
#176
With most of the new cars way to light, I think there is no Problem with "balancing" the car.
Also different Electronic parts are different... Motors can be 10-20g different, ESC also, Servo 10g... I think you cann get 50g diffence only on the left side.. and when you drive 6000 or 8200 its aout 70g...
So you have anyway to balance it.
#177
Going from an Mi7 to the Mi8 I noticed pros and cons of this.
The Mi7 felt like it had faster corner speed with mid motor.
The Mi8 with equal belts felt more efficient mid to exit with getting up to speed. But lacked that corner speed snap the 7 had.
I think both have their benefits with sacrifices.
#178
Release day tomorrow.
#179
I'm probably not going to be able to resist buying one of these... especially since it's got some red anno. So where do I get one
#180
Centering the motor in the car has more to do with the spinning mass the motor creates when operating at higher RPM's. This creates an offset torque that messes with the overall balance of the car even though car is statically balanced. Think bubble leveling a car tire to balance vs Dynamically balancing by spinning it.
