Like Tree307Likes
New IRIS by AME
Old 11-17-2022, 09:20 AM
  #151
I hope it's not a 3 belt car.. 3 belt, in my opinion, is a compromise as a result of the chassis layout. I have yet to see an efficient 3 belt electric car. Every 3 belt car I have seen had extra drag in the drive system which isn't ideal for electric racing.
I am hoping for a 1 or 2 belt solution.
gigaplex likes this.
malkiy is offline
Old 11-17-2022, 09:23 AM
  #152
Could be one belt I think... this is torture 😅
DavidNERODease is offline
Old 11-17-2022, 09:47 AM
  #153
Originally Posted by DavidNERODease View Post
I'm having a hard time figuring this one out too
The chassis cuts for diff/spool are so narrow it would make sense to be single belted, but the shafts in oposing directions are boggling me. If they avoid using 3 belts, this is going to be very interesting.
The motor appears to be mounted higher than usual too, but I'm sure it's only a false impression.
mr.rev is offline
Old 11-17-2022, 10:23 AM
  #154
The motor mount appears to be designed to have a belt run between the mount and motor face (connecting the two layshafts with a third belt). So centred diffs with a very short front belt which might make the car easier to drive.
The motor must be mounted with the 2 o'clock and 4 o'clock holes.
gwhiz and mr.rev like this.
Old 11-17-2022, 03:58 PM
  #155
TryHard's Avatar
Like this.
Blue belts are on the centreline, black is offset towards the the motor side, and runs through the bulkhead. Does look like clearance on the mount indicates larger pulleys, at least for the middle belt.
kentech, DavidNERODease and h2e like this.
TryHard is offline
Old 11-17-2022, 04:25 PM
  #156
Airwave's Avatar
I think there is a part missing to fix the motor. What would be the interest to use a third belt if you are not centering the motor at maximum?
Airwave is offline
Old 11-17-2022, 05:04 PM
  #157
gigaplex's Avatar
Might be a dual spur design.
gigaplex is offline
Old 11-17-2022, 06:01 PM
  #158
Super Moderator
Marcos.J's Avatar
Trader Rating: 235 (100%+)
too far apart , the gizmo had the layshafts closer together
Marcos.J is offline
Old 11-17-2022, 06:20 PM
  #159
rccartips is offline
Old 11-17-2022, 08:19 PM
  #160
Three belt.
The motor slots dont go far enough into the center and the mount is spaced thicker where it mounts.
Robbob is offline
Old 11-17-2022, 10:26 PM
  #161
So a spur gear of some kind on the end of the left side layshaft? The shaft looks longer there and the mount has more reinforcing.
Scott_T is offline
Old 11-17-2022, 11:14 PM
  #162
Maybe the thord belt runs around the motor? That might be reason for the large pulleys.
Papi is offline
Old 11-18-2022, 05:45 AM
  #163
sosidge's Avatar
Huge lump of aluminium in the middle of the car = too stiff
Three belts = inefficient
Barely any pinion clearance = modified motors only
Looks like it will be a massive success!
rccartips and gigaplex like this.
sosidge is offline
Old 11-18-2022, 06:28 AM
  #164
Looking at how the motor mount lines up on the chassis plate, there should be plenty of flex in the front half which seems to be the working trend. Pinion clearance is indicated by the slotted screw holes... looks like enough range to me. If it's done right, 3 belt efficiency will be okay... maybe not the ultimate VTA car but I'm sure that isn't the market they are going for.
Old 11-18-2022, 08:59 AM
  #165
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
i believe it is either 3 belts or some sort of pulley / support system to allow for 1 belt
happy to see at least some new / renewed thinking within TC designs --- and not just a copying of others.
EDWARD2003, gwhiz, glennhl and 1 others like this.
hanulec is offline
